Question about Linare Desktop, AMD Sempron 2200,40 GB HDD & 128 MB RAM
Desk top overheating
My client has a desktop with an overheating problem. He thinks it is dirty or a fan problem. How long should it take to analyze the problem and how long should it take to remove and replace the fan if needed? He also wants to put a key on his router to beef up security. Is there a common TCP/IP address to use to do this? The last time I did it on my network it took about an hour. Is that about right?
    President:
  • 2,559 Answers
It'll take about 5 minutes to analyze the fan issue (This is just for removing the covers from the computer)and about 1 minute to replace it if needed.
Also setting the security will take about 5 minutes as well and I need to know the router brand to give IP address for router page.
Posted on Jun 01, 2009
    President:
  • 948 Answers
About 15 min to replace a fan. Adding a key for wireless networking probably another 15 minutes if you are very skilled, 30 min to an hour if you have to muddle through it looking things up in the manual or online. There is no standard method of accessing the settings on the router other than plugging into a wired connection and using the web browser to go to http://<router IP address> and entering username/password combination.
  • Dick
    Dick Jun 02, 2009
    Any update on this? How about rating the solutions given?
What cause my computer to shut down automatic and boot up again?
Overheating. Check the cooling fan and the heat sink fans for dust.
Feb 15, 2018 | Top Computers & Internet
Tip
Laptop or desktop computer overheating? Follow these tips to solve the problem
If you think your computer or laptop is overheating, follow these tips to solve the problem:
1) To confirm that overheating is the problem, install CPUID's Hardware Monitor (free download here):
http://www.cpuid.com/hwmonitor.php
Install Hardware Monitor and run it. The temperature of your CPU should be lower than 70 C for a laptop (lower than 60 C for a desktop PC). The temperature of your video card should be lower than 60, even if you're running a complex 3D game. The temperature of your HD depends on your manufacturer, but it should never be higher than 45 C (55 C for a 10,000 rpm driver)
2) To keep computer heat as low as possible, clean up your laptop or desktop regularly, removing dust and dirt. Remove the computer cover and use a compressed air can to blow the dirt out. Also, take care of verifying that the fan(s) move easily.
3) If you have a desktop computer, avoid placing it directly on the floor, since they will collect more dust thsi way. Place it on your desk. Also, avoid putting it inside any enclosure. Allow at least 3 inches between the sides of the case and a wall to allow plenty of air circulation.
4) If you have a laptop, avoid using it on top of any fabric (blanket, bed, pillow, etc). This blocks most of the airflow, causing overheating.
5) Laptops are not optimally designed for heavy gaming, which stresses your CPU and video card, producing very large amounts of heat. In other words, if your laptop overheats while playing 3d games, accept that this may be just normal for your machine... or play your games on a desktop PC.
6) Overclocking your CPU, GPU and/or FSB will produce much more heat than normal. To avoid the extra heat, do not overclock.
Read my other tips to keep your desktop or laptop computer running at top efficiency, including some tips about speeding up a slow computer.
on Mar 23, 2010 | Computers & Internet
Desk top computer w/ SN: CNH4390C89, P/N PJ506AA, won't turn on. when it was working, fan was noisy most of the time
The computer fan may be clogged with dust or may have failed. The computer monitors the fan and if it is not working it will not let the computer start. It is a way for the pc to keep itself from overheating. Unplug the computer and open the cover and carefully try to vacuum or blow out all the dust. Then with the cover off try starting the computer and watch the fans and see which one is not turning, it may start if there was a lot off dust. If not the fan may need to be replaced.
Thanks for using FixYa.
Jun 20, 2011 | HP Compaq Presario SR1215CL (82916052980)...
Dell Dimension 4600C Compurter running fast and
Try to check the fan and the inside of the desktop for any dirty things in there. Especially check the fan to see if something is stuck!
Mar 04, 2011 | Dell Dimension 4600 PC Desktop
Why does my lap top hp screen goes black seems like it is getting hot.
i think it's overheating, check the fan of your laptop if it's working it might be dirty...
Sep 03, 2010 | Computers & Internet
Fan works randomly....when it's not working plug
Hi, If the computer is hot near the electrical plug in the back of the computer then the power supply needs to be replaced. This will also cause overheating problems if the fan does not exhaust enough air. You should not run the computer in this condition because the power supply can short out and take other components with it. Also there is a risk that it will burn up. Power supplies are very inexpensive and can be changed by anyone with basic computer repair knowledge. Hank
Jul 26, 2010 | eMachines T5212 PC Desktop
When powering on the tower the fans start and the tower shuts down. Is there a solution
Your fan is dirty so its overheating, the pc is turning off to protect itself, you should open the tower and clean out the fan
Jun 09, 2010 | E-Machines T5082 PC Desktop
HP PC m7250n- fan always on high speed
question = are u over clocking ? and /or is your processor fan and fins dirty causing over heating causing the fan to run on high trying to cool down a heated/overheated processor.
May 01, 2010 | HP Media Center m7250n (ED842AA) PC...
Cooling fan runs constantly coming off stand-by
Has it always done this or is this a recent problem?
Try this: right click on your desk top's start screen, select properties, select screen saver, select poweer, select hibernate. Make sure that hibernate is checked and select apply. Now when you hibernate your computer will remember all the info you were working on AND it should make the fan run normally on start up.
Not all computers have the hibernate feature and it cannot be added, so let's hope yours was built with it at the factory. Good luck!
May 01, 2009 | Computers & Internet
Computers & Internet Logo
119 people viewed this question
Top Linare Computers & Internet Experts
gautam jha
Level 1 Expert
Carlos L. Burgos
Carlos L. Burgos
Iqbal Husain
Iqbal Husain
Are you a Linare Computer and Internet Expert? Answer questions, earn points and help others
