Question about Taylor 632-33 Ice Cream Maker
Taylor 8756 ice cream machine clogs at face
Have a Taylor 8756 ice cream machine which stops dispensing product after turned on and freezes down. It's clogging at the face somehow. Can unclog if with a wire up the draw spout. Taylor rep says never heard of this issue. Anyone have any ideas?
  • 3 more comments
  • what is the exact model # and serial # of your machine. Is it 8754-27 or 8754-33?
  • Alabao Bacalao May 11, 2010
    Please be more specific. After the freeze down cycle, what is happening? What type of producy are you using?
  • Allen
    Allen Mar 01, 2014
    3/1/14 - I am having this EXACT same issue with my Taylor Model 8756-27 (air cooled / single phase) right now! Unit was just started up for the season, worked initially, then port inside of face plate clogged with ice and product would not dispense! If anyone has any ideas of what I can adjust / check to prevent this from reoccuring, please advise!
  • Joec
    Joec May 01, 2014
    I am having this same issue with the twist. I put the machine together around 9 am. By 5 p.m. the twist stops working and one of the orings break on the middle draw valve. I have no idea what it is doing this. I have two of the same machines, other one is working fine. After I replace the oring, I have to wait a few hours for (I guess ice that forms) thaws. I called taylor, they never call back. Any help?
  • Jorge Casillas
    Jorge Casillas Aug 16, 2015
    First check your bladesif they are worn this situation will occur and cause the unit to run longer therefore having a frozen barrel
    Habit-Forming:
    New Friend:
  • 8 Answers
First check your blades if they are worn out the machine will ice up in chamber and the unit will have a hard time dispensing.Then if blades ok check your mix is it plenty or lacking sometimes customers wait to sell all ice cream not reallizing that this will affect product qualityand unit will freeze up too much giving you problems.
Posted on Aug 16, 2015
Can i see a display of internal shake machine?
Posted on May 05, 2010
I need to know where i may go to get directions to put this taylor 8756-22 ice cream machaine back togeather if you can help please e-mail me at johnjohnson1967yahoo.com thanks
Posted on Nov 06, 2009
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 107 Answers
Clean as per this manual http://www.taylor-company.com/service/resources/op_man/8752_8756_8757op0.pdf. if mix is over beaten will create ice crystals in mix which in turn could over time clog the door make sure you have adequate mix in barrel and its not freezing solid.Make sure all orings and springs are good and properly lubed in pump.
Posted on Apr 23, 2012
I have a Taylor C707-23 that is freezing the product in the barrel and not dispensing. Then the drive motor trips. Had the sensor probe changed same thing.
If this is an ongoing problem that you have had for a while, it sounds as though your viscosity may be set too high. You can adjust the viscosity by removing the 4 screws that hold the face plate on. You will see 3 potentiometers. You want the left most potentiometer. It Should be labeled "Viscosity". You need a tiny screwdriver to turn it. Turn it counter clockwise about 1/16th of a turn. If your Ice Cream is already frozen, You will have to let it cycle a few times before the ice cream reaches consistency. If its liquid, then you will know as soon as the machine finishes the initial freeze down cycle.
If this is a new problem, then it is highly likely that your beater motor is going bad. To check this you would want to test the amperage of the motor when you initially draw product from the machine. A single phase 1.5HP motor in the taylor ice cream machines should not draw more than 7 amp on an initial draw right after freeze down. Its normal to draw around 6 amps then drop for a few second. In order to trigger the reset, the beater motor has to draw more than 6.3 amps for an extended period of time. Your reset may be set higher than 6.3 but that is average.
Jan 16, 2018 | Taylor Ice Cream Makers
Does the taylor model 8756 put out a substantial amount more product than the 754?
Absolutely! The Taylor 754 and Taylor 794's are capable of 284 3 1/2oz. servings per side / per hour. The 8756 is capable of 426 of the same 3.5oz. servings. The 8756 packs more air into the product making it easier to freeze and reducing recovery time.
Soft Serve Parts Taylor Machines
May 07, 2017 | Taylor Ice Cream Makers
Taylor 8756-33. Which components operate in standby mode?
In standby mode, the machine just wants to keep the product refrigerated until it goes back into auto.
So, the mix cabinet needs to keep the product cool in the bottom of the machine, that requires the mix compressor and fans to run. The mix cabinet temperature is read by a thermistor probe and regulated by the (left side) logic board.
The product in the cylinders should go back to liquid form in standby, but we still have to maintain that safe food temperature, the motor and compressor will run periodically. If the machine is air-cooled a fan will run anytime the compressors run. If it is water cooled, water will flow through the machine when the compressor runs. The temperature in the freezing cylinders is read by a different thermistor probe and regulated by the logic boards.
Here is a link to all of the parts in a Taylor 8756.
http://www.softserveparts.com/c-1335911-parts-8756.html
Jul 20, 2015 | Taylor Ice Cream Makers
Why is my taylor 8756 - 27 freezing the chocolate side and will not dspense?
This seems like it could be many things. Is the pump coming on when you try to dispense? Can you stick a thin wire up through the feed holes in the chocolate side when you try to dispense to help free the product?
May 04, 2014 | Taylor 754-33 Ice Cream Machine Soft Serve...
Product comes out frozen after all night on standby in a 754 taylor
The same thing happened to my Taylor 8756 and it was the thermistor probe. The probe is a thin copper tube that is near the freeze cylinder. It cost me about $20 for the part and $200 for the labor to have a technician put it in. Hope this helps and good luck.
Apr 18, 2014 | Taylor 2001 754 Air Cooled Soft Serve...
Manual and guide for Taylor ice cream machine model 8756-33
For Taylor ice cream machine maintenance, please see our Support page or our Youtube channel. Providing ice cream equipment maintenance to you for free!
Slices Concession
Aug 07, 2013 | Taylor Soft Serve 8756 Three Phase Water...
Pump loses prime causing ice cream to spit out.
If it is "spitting" you might want to check all the components from the mix container all the way up to the door where ice cream is dispensed. Check for leaking mix hoses as well as broken or clogged diaphragm (inside fitting in mix cabinet). Refer to the manual to find the diaphragm.
Aug 26, 2012 | Taylor 2009 Model 8756 Soft Serve Ice...
Owners manual taylor ice cream machine model 8756-27
Slices Concession
Apr 25, 2012 | Taylor 2009 Model 8756 Soft Serve Ice...
Spares for Taylor 8756 ice cream machine
you must buy replacements from your local tatlor dist. 700-900$
You will find that responce from all of thier part suppliers carrier is a very well insulated company.
Jul 29, 2008 | Taylor 632-33 Ice Cream Maker
Ice Cream Makers Logo
1,548 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
