Is there a fuse to be changed within the monitor. there is no power supply box dealy on the power cord
SOURCE: Dell 19" Monitor - Dead
go to lcdrepair.us you can buy the board you need there , you can talk to tim he can help you out or email him
SOURCE: usb ports on 1703fpt do not work
you have to connect the monitor with a usb cable to your computer, then you can use its usb ports, it's just a hub.
SOURCE: monitor shuts off but green light stays on
there is no solution a chip is fried i just opened mine up it blows
SOURCE: Monitor not turning on and no power- Dell E198FP
Your monitor have a bad condensatorin the PSU.
The only thing to
do is to replace the Power Supply Unit (very expensive, more than a new monitor) or if you have
electronic tools, found and replace that condensator.(cheaper way...)
Best Regards!
SOURCE: My Dell 1905FP 19 monitor went black & green power light flickers
It sound like a short circuit. I had this problem with 1907FP model. It had an USB port on the monitor which got damaged and it was shortening to the groung. In your case it might be a bad internal power supply board.
