Question about Sharp EL-531VB Calculator
Factorial of numbers
I wish to get the "factorial" of 20! What button do I press
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
Look above number 4 there should be 'n!' in yellow color that is the factorial so just type 20 then shift 4, shift is the yellow button in the top left. Hope you find it.
Posted on Jul 07, 2009
Can't find code for my bush tv model number btvd 91186b
code ..
just read through a bush TV user manual
does this help any ?
6.LOCK MENU
To enter the LOCK Menu, press MENU button and then press or buttons to select the LOCK Menu.
The default password is 6666.
Please set a new password to so it is easy to remember. Follow the on screen steps to set.
FACTORY RESET NOTE:
If you wish to reset your TV, please select the Restore Factory Default option, this will clear all settings.
Free Bush Flat Panel Television User Manuals ManualsOnline com
Jul 15, 2016 | Bush Televison & Video
Hi. Can you please tell me the correct code for the Curtis tv for Cablevision Remote? We have two remotes now, the cable remote cannot operate the volume or the power on/off tv, must use Curtis remote.....
Hello
Codes for Curtis TV with Cablevison remote control are:-
070 004 101 127 236 011 072 081 120 164
*Tip: The iO button will light on for 20 seconds. The
next step must be entered while the iO button is
on.
STEP2 Press the [INFO] button.
The iO button will blink number of times indicating the
number of each digit of the code number. Each digit is
separated by a 1 second interval of the iO button being
turned off.
Example :One blink, three blinks and eight blinks with
an interval of 1 second of iO button being
turned off, indicates the code number 138.
Note :Ten blinks is equal to the number 0.
D. Program the Volume Controls.
By following the steps below, the user can program
the volume controls (Volume UP, Volume Down and
MUTE) . The default volume control settings on the
remote control is TV volume control. If you wish you
can control the volume via your CABLE box, use the
following steps.
STEP1 Press the [CBL] button and the [SEL] button
simultaneously for 3 seconds. The iO button
will turn on.
*Tip : The iO button will light on for 20 seconds.
The next step must be entered while the
iO button is on.
STEP2 Press the [VOL +] button.
STEP3 Press the [CBL] button.
The iO button will blink twice to confirm the
programming.
To return to original state:
If you wish you can control the volume via your TV,
repeat the above steps by pressing [TV] in STEP3 .
OK.
Dec 23, 2010 | Curtis CM13102 13" TV
PHONES WILL NOT RING
To change the ringing on a Prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
enter in #62 the screen should say day ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
press # when finished.
If I posted this before, I apologize. The problem's not showing up on my solved page
Dec 15, 2010 | Samsung Prostar 816 Phone
Please help us program a Uniden BC340CRS scanner.
To program a known frequency into the BC340CRS:
- Power the scanner ON
- Press the E/PGM key to enter programming mode
- Enter the number of the channel that you wish to program
- Press HOLD
- Enter the frequency, including the decimal point (e.g., 156.225)
- Press E/PGM to enter the frequency into memory
Press the UP or DOWN arrow to advance to the next channel you wish to program
Press HOLD or SCAN to exit the programming mode.
More detailed programming instructions can be found in the factory operating manual which you can download and print, free of charge, here:
http://www.radiopics.com/1.%20Manuals/Bearcat/Bearcat%20BC340CRS%20%28Manual%29.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Oct 23, 2010 | Uniden BC340CRS Base Scanner
I have a prostar samsung 816 plus and we have a number of phones in the office and only one is ringing, how can I make them all ring?
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
Jun 24, 2010 | Samsung Prostar 816 Phone
Some 816 phones won't ring on incoming calls
Jun 05, 2010 | Samsung Prostar 816 Phone
After a series of power outages and brown outs over the weekend, our system has lost all of the predialed #'s and only one phone in the whole office (10 phone) rings.
Sounds like the system defaulted programming.
Depending on the type of prostar 616 the only ringing station would be 1(or 21) with the porstar or 4(or 24) with the prostar plus.
To program system speed dial numbersyou need the customer programming enabled (see the first part of programing ringing)
press the ALM/SD button
dial the 2 digit speed dialcode 10-98
dial the telephone number to be stored in that speed dial bank
press ALM/SD to store the number
Jun 01, 2010 | Samsung Prostar 816 Phone
How do I program prostar 816 to ring?
with the handset down enter #20 the screen should say MMC DISABLED
Mar 09, 2010 | Samsung Prostar 816 Phone
THE PHONES DO NOT RING
with the handset2.gif down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming2.gif)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished.
Oct 01, 2009 | Samsung Prostar 816 Phone
Phone dont ring
1) enter in 1 2 3 4 1 # (that enables programming)
press #when finished. hope that helps
Sep 04, 2008 | Samsung Prostar 824 Keyset Telephone
Sharp EL-531VB Calculator Logo
193 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
