Question about Crunch Drive V-600 Car Audio Amplifier
I have a crunch drive car amp
And the left out put dosn't work and it won't brige and i put new fuses in it to
  • 655 Answers
Hello cocacolaman,
If you have checked both onboard fuses and they are OK, then most likely the left channel is blown. That's a component level repair. I'd recommend having the amp tested at your local car audio shop. They should also be able to advise you better on whether to repair or replace the amp.
Hope this helps.
Posted on Jun 02, 2009
Right turn signal dosn,t work
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Jul 19, 2016 | 2003 Lincoln LS V8
Crunching and grinding
sounds like a strut mount
Mar 28, 2014 | 2001 Toyota Altezza
Left headlight
If the other head light works ,it won't be a fuse
Check every fuse in the car,won't take long &
the fuses will protect a complete circuit,not just
a couple head lights.
The light switch has a circuit breaker not a fuse.
Have you removed & tested the lamp it'self
No owners manual? Need that for fuses & bulbs/lamps
Sep 04, 2012 | 2001 Hyundai Sonata
Drive V-600 Car Audio Amplifier: lost rt channel...
you have blown out the channel expesive to fix you will have to now brige the unit to run the extra speakers for bridging diagram email me
May 16, 2010 | Crunch Drive V-600 Car Audio Amplifier
Good day, I have a Crunch P2200 Powerzone.Lately,my fuse from my dc12v source bursted but the fuse on my P2200 was intact and okey.I later found out that R550 was burned (i dont know the value coz it was...
Hi mate i had similar problem my 12 volt blow all good i thought every thing worked after fixing but i noticed my bass was weak subs would still move a lot but not pump no real bass coming from them .After eliminating most things i hooked dvd player to amp with cd inside to test if head unit was outputing bass and i found that my head units bass out put had a cry but fuse in headunit was fine and i was fused in 2 spots from 12volt source new head unit and all good again hope this helps
Oct 19, 2009 | Crunch Powerzone P2200 Car Audio Amplifier
Hooking up system using HI-INPUT amp wires.
This may sound dumb, but are there any other inputs left on the amp? Most amps that i have worked with have a special set of inputs for high input. (by high input you mean speaker level right?) If those exist the obvious answer is to use those. They should be labeled, so just hook them up according to them. You may need a special adapter from the amp manufacturer. If you dont have any high level inputs or any not broken inputs left you have two options. You can either A: junk the amp or B: open it up and solder new connectors back on. (it sounds harder than it really is. There are four large pieces of metal to solder onto the board for a set of inputs)
May 27, 2009 | Crunch Powerzone P480 Car Audio Amplifier
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
No sound
hi there
on your CD deck or what ever unit you plugged the RCA wires to needs to be set on subs the radio needs to be set to put sound to your amp.....on your CD player if you press the F/function button a few times it will scroll to SW which is for the subs set this to the on position or if your CD player has a button with SW press it and turn on this feature......if this has been done......check the fuse or fuses on the amp.......if you have done all of the above check the back of the CD unit to make sure you are plugged into sub-woofer RCA or R (rear) RCA ..........sometimes people accidentally put the RCA wires into the aux input RCA,,,,,, double check this.........
hope this helps
Mar 07, 2009 | Crunch PZi1000.1 Car Audio Amplifier
CD player looks like its working but no sound. Quit during Play.
HI...CHECK TO SEE IF THE AMP IS GETTING POWER (REM) POWER-----(AMP)POWER--GROUND,, CHECK FUSES BOTH OF THEM--....YOU MAY HAVE DONE THIS ALREADY--CHECK TO SEE IF THE RADIO FUSE IS OK (POWER)..THE DISPLAY CAN STILL WORK FINE BECAUSE THE RADIO HAS 2 FUSES 1 FOR (POWER) AND ONE FOR MEMORY(DISPLAY) HARD TO SAY WITH OUT LOOKING AT IT.... GOOD LUCK
Feb 12, 2009 | Crunch BLX5520 Car Audio Amplifier
One speaker is working more than the other
I would replace the wire your sub is hooked up to and try hooking up the sub that was sparked to the opposite channel on the amp to make sure the amp is not the culprit. Also switch RCA cables L to R, R to L
Feb 02, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Crunch Drive V-600 Car Audio Amplifier Logo
77 people viewed this question
Top Crunch Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Matthew Spark
Matthew Spark
Tygh Duval
Tygh Duval
Are you a Crunch Car Audio and Video Expert? Answer questions, earn points and help others
