I have the above Ipaq that use to work fine with my MS XP operating system. Now I have Vista premium and it doesn't work very well if at all. It does recognize it sometimes but I checked the MS site and there is no sync software for vista and this model Ipaq only newer models, because of the Ipaq OS. Is there away around this so I can use my Ipaq, with out upgrading the OS. Or should I just get rid of Vista!!! My ipaq 1945 is stuck on the HP screen 1.07 and will not sync after I was told to hold the power button down and reset
Hi. While holding power button, and pressing reset will do a hard reset to your PDA (reset the device to its factory default settings). So if your PDA is working well, don't do it. As for the syncronization with your Vista PC; Winodws XP uses the ActiveSync software for syncronization, and for Windows Vista, Microsoft developed a brand new syncronization software called "Windows Mobile Device Center". It can be downloaded here: (http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-center-download.mspx). When you download/install this software to your PC, you should be able to connect your PDA to your PC without any problem, and definitely without changing any OS in your PDA or PC. Hope this helps.
how do i transfer data from a usb flash drive onto my ipaq PDA. the ipaq PDA does not have a usb...
(More)
how do i transfer data from a usb flash drive onto my ipaq PDA. the ipaq PDA does not have a usb port
My pocket cd is so ruined it cant run in my drive, so i cant install my drivers for the pda on the...
(More)
My pocket cd is so ruined it cant run in my drive, so i cant install my drivers for the pda on the comp, and i need to install my TOMTOM Navigator, but i cant get it insatlled on my PDA, the files is transfered but the program isent there..? What should i do?
My HP 3115 Is not loading when I turn on or resets, It show this screen that it says HP invert with...
(More)
My HP 3115 Is not loading when I turn on or resets, It show this screen that it says HP invert with this # 1.00.10A and it and the bar does not load all the way. can some please help me!! Thanks.
When I insert my battery the HP home screen is frozen with 1.07 showing. I can't proceed or do...
(More)
When I insert my battery the HP home screen is frozen with 1.07 showing. I can't proceed or do anything? HELP!
My Hp ipaq h1940 pocket pc is frozen on the hp opening page with 2 1.07 at the top I have tried soft...
(More)
My Hp ipaq h1940 pocket pc is frozen on the hp opening page with 2 1.07 at the top I have tried soft and hard reset and removing the battery.
