Question about Haier ESD400 Stainless Steel 24 in. Built-in Dishwasher
Haier buttons not working!
I have a Haier dishwasher that is not even 6 months old. The right side (buttons) will not work! Help! I have a Haier ESD 402 dishwasher also and the exact same thing happened to me last week. We have had our dishwasher since July of 2008. I have emailed the Haier company to see what they are going to do in regards to fixing the right side of the control panel? I'll let you know if I get a reply.
  • 17 Answers
From previous experience, I would bet that the circuit board/ control panel is failing. The one I had leaked steam near the top of the unit and the condensation will work it's way into the top control panel. Bad design on Haier's part. The worst part about mine was there is no adjustment for the door. I ended up getting a refund on the unit and buying a very nice LG model. Good luck dealing with Haier. They will send A&E factory Service out and they are not very good. I would suggest getting rid of the Haier. (personal opinion)
Posted on Feb 09, 2010
Haier dishwasher stuck on auto wash
I think the flood switch has triggered which forces the pump to run continuously but does not take any other input. I am assuming it is the pump sound that you are hearing as soon as you connect power to dishwasher. The float switch is at base of dishwasher. You can press the disc visible near the filter sump. It should move up and down when you press it. If it is not moving then the spring is stuck and needs replacement. However if the disc is ok but you are still getting the problem, then you will have to check for flood switch failure. The flood switch is under the dishwasher and to access it you will have to pull the dishwasher out and lay on side. Make sure the mains power is disconnected and water inlet tap is shut.
see items 17 and 21 in this diagram.
http://www.searspartsdirect.com/partsdirect/part-model/Haier-Parts/Dishwasher-Parts/Model-DWL7075MBSS/3126/0130000/50037858/00001?blt=06&prst=&shdMod=
might be a bit slow to view.
Apr 19, 2014 | Haier DWL7075MBSS 24" Built-in Dishwasher...
My dishwasher from ikea renlig dw 60, is 6 month old and now the light to select the programs stay red all the time and pressing the selection button doesnt do anything. Thanks for your help
Similar just happened to us. Turned power off, waited a while, opened door. pressed and held power on button then pressed and held also the select button. Brought it back to life. End leds lit up and i could then select and worked when i shut the door. Ours is a smaller Renlig. Good luck.
May 27, 2011 | Dishwashers
I have had a Haier Dishwaher ESD300 for about 2 years. It suddenly just stopped. None of the buttons will work. I have checked fuses etc. All of that is fine. Wondered what I could do to fix the problem.
My dishwasher had the exact same symptoms. The control panel was faulty. I discovered this by testing the connector with my multimeter, looking for the LED connections. When I wasn't able to find anything, I carefully peeled it off. (See picture.) I expect at least one of the traces underneath the nasty brown line is faulty, causing the control panel to not function. On the control board, I jumpered the first pin to the fifth pin from the bottom of the connector, as viewed with the Haier brand right-side up, and pots & pans started right up.
flszen.jpg.
It looks like I can get a replacement control panel from Sears Parts Direct for $30.
Dec 28, 2010 | Haier ESD300 / ESD301 Built-in Dishwasher
I have had the dishwasher for about 2 years. I suddenly just stopped. I can't get any button to work.
flszen.jpg.
We have a Haier DVD101B dvd player that won't work now...
At least you got 6 months of use out of yours, which is 6 months more than I got out of mine. I took mine out of the box and it would not even turn on. When I called the manufacturer, they said they could not help me at all. I bought it for my daughter to take to college, and I guess it is just going to go in the trash.
Jul 29, 2010 | Haier DVD101 DVD Player
Settings buttons partially work and will not start
Basically, the Haier is a piece of ****. Parts are not available and the phone-in service (if you can call it that) will keep you on hold endlessly. Do yourself a favor and get a better machine.
Apr 19, 2010 | Haier ESD400 Stainless Steel 24 in....
Haier ESD400 Stainless Steel 24 in. Built-in Dishwasher Logo
765 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
