Question about Whirlpool GEW9250 Electric Dryer
Whirlpool Gas Dryer Timer problem
The timer is broken on my LGR7646JQ0 (the knob does not automatically move to the OFF area). My mother and I fought all day about whether I broke the machine by turning the dial counterclockwise (which is actually how I broke our old machine) but this one seems to have no problem with turning both ways. I looked in the manual and there is no direction specified. Can anyone resolve this dispute and suggest how to fix the timer?
  • 6,784 Answers
OK, this timer is designed to spin in both directions and, if you have to advance this timer in any way to complete a cycle, you will need to replace this timer asap.
In most cases, the mechanism will fail, causing this non advancement stage(stalled timer mech).
replacing the timer will fix this issue.
Posted on Jun 01, 2009
Gas dryer dries sporadically. dial for automatic dry doesn't move
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ...Replaced outlet, cord, and moved the outlet so we don't have the same ... Whirlpool LER4634EQ0 110 v timer motor, when timer contacts TM .... David Villa 7 months ago ... 3 years and now thedryer won't heat and the timer doesn't advance, ...Missing: cu
Nov 17, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
Need control knob timer dryer doesn't shut off
If you are stating that the timer knob never moves to the off position, then the timer is probably bad and needs replaced. If you can't turn the timer because the knob feels too loose then possibly the knob is just broken. Timer knobs usually just pull straight off so you can look at the back side and see if the plastic around the shaft hole is cracked.
May 11, 2015 | Whirlpool Dryers
The selector knob on my Whirlpool LER4634JQ1 does not move, so the dryer will not turn off automatically and no "end of cycle" buzzer sounds. Do I simply replace the timer?
Your timer most likely does need to be replaced. The timer has a small motor that causes it to rotate during the cycle and those can go bad causing the timer to not advance. Unfortunately, you cannot get just that timer motor anymore. Hope this helps!
Feb 16, 2015 | Whirlpool Dryers
Dryer does not stop - timer knob does not turn so dryer continues
do you have it on more or less?,if so the timer will not move unless there is heat, do you have heat?are the clothes drying ?if you have it on time dry the timer is bad try moving it past the spot were it's sticking and see if it counts down
Nov 03, 2009 | Whirlpool GGQ8831L Gas Dryer
When u turn on my gas whirlpool dryer it runs as normal. when u check on it a little later (on automatic dry) the timer has not moved, and the dryer has quit producing heat
Hi, the timer control the heating commands and, if its not moving(rotating), this will confirm timer failuer. replace it asap.
Jun 18, 2009 | Dryers
Dryer turns but no heat and knob doesn't move
Check the switch on the motor. It may have failed, or has a wire/terminal broken/disconnected. It is a multi-contact switch. both sections must click. Could also be mechanically loose on the motor and therefore just not getting fully activated.
Hope this is helpful.
Apr 04, 2009 | Whirlpool LGR5636L Gas Dryer
KITCH AID DRYER
It sounds like the timer motor isn't advancing. You will have to replace the timer.
Oct 15, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryer doesn't get hot or turn off.
yes very possible timer but my guess on the times i seen the problem would be the heating element are the thermo fuse on the elemnt canister when the heater does not come on the timer will not move ck the heater and the fuses on the heater canister it will fix your problem
Feb 28, 2008 | Whirlpool LER4600 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
144 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
