Question about Singer 5050 Mechanical Sewing Machine
Bobbin issues Bobbin tension on my Singer 5050c is too tight. What could the problem be? Please help me resolve this issue. Thanks.
  • 25 Answers
Take out your bobbin case... there should be a small screw fixture on the side of the case...turn screw anti clockwise until you get the correct tension ... To test the bobbin thread tension...Remove the bobbin case keeping bobbin attached and hold it by suspending it by the thread...**** it once or twice, if the tension is correct the thread will unwind by about an inch or two. If it does not unwind at all...tension is too tight. If the tension is too loose it will drop too much. Goog Luck
Posted on Jun 02, 2009
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
I need elp with tension on singer cg550
You didn't explain the symptoms. Is the thread bunching, looping, knotting under the fabric? Is the bobbin thread rising to the top of the fabric?
If it is bunching under the fabric, it is probably what is called thread nesting or bird nesting. There are several fixes, sometimes more than one fix is required to resolve the issue.
Be sure to clean under the needle plate, around the bobbin, and the feed dogs. If the machine has instructions for oiling, follow the directions using a fresh, good quality sewing machine oil and apply only 1-2 drops each spot.
Install a brand new needle. Make sure you are using a needle compatible with the thread and fabric being used. All About Needles
Best practice is to use the same thread in both the upper and bobbin. Also, avoid old or bargain bin thread. Spend an extra couple of dollars to reduce frustration and increase success with your machine. If you wish, you may use two different colors of thread to test so you can easily determine what is happening with the tension.
Remove the thread from the machine. RAISE the presser foot and rethread from the beginning--the thread needs to be seated firmly in the tension disk. Verify that the correct thread path is followed (consult the owner's manual).
Set the upper tension to the midway point between high & low numbers (this is the factory standard and is a good place to start, but every machine is different and may need adjustment).
Confirm that the bobbin is installed in the bobbin case (turning the correct direction) and that the bobbin case is threaded properly.
Before beginning to stitch, hand rotate the handwheel one rotation and pull the bobbin thread to the top of the fabric. Then, gently hold the thread tails in the left hand and slowly begin to stitch.
Test.
If thread is bunching, looping under the fabric, the upper tension is too loose. Tighten it and retest. On most machines, the lower the tension number, the looser the tension.
If the bobbin thread is rising to the top of the fabric, the upper tension is too tight. Loosen the upper tension and retest.
Keep adjusting and testing until it is where you want it. Generally, tension is correct when both threads (upper & bobbin) meet in the middle of the fabric. FWIW, tension is static and should be tested and readjusted every time a new project is begun. The needle, thread, and fabric will affect the tension, so it is important to get comfortable adjusting the tension.
Also found the following reviews. Appears that some users have had tension issues with their CG550.
Amazon com Customer Reviews Singer CG 550 10 Stitch Commercial Grade...
Mar 17, 2016 | Singer CG550 Mechanical Sewing Machine
Singer 301 won't stitch properly, thread bunching up on underside
Likely that it is a lower tension issue
Bottom tension is controlled by the bobbin case. First, ensure that the thread is wound tight onto the bobbin (should not be spongy when you push your fingernail into into it) Looking at the open side of the bobbin case, insert the bobbin into the bobbin case (so the thread winds off in a clockwise direction) and feed under the 'tension finger'. If you now hold the end of the thread, suspending the bobbin and case from it, the assembly should not drag any more thread out of the bobbin case. If it does, the small screw on the tension finger needs to be tightened slightly. If the assembly does not drag out any more thread, give the thread a little upwards tug. The assembly should slide down a little.If it does not slide, the tension finger is too tight - loosen it a little.
Insert a NEW needle, make sure the top thread is correctly threaded and tension is set at the 'normal' setting (as per book) ..... .... try sewing a sample. Note: using 'cheap' thread will cause all sorts of tension issues as well as fluff up your machine fast - avoid it!
Good luck
Oct 12, 2013 | Bernina Artista 180
Singer 7468 birdnest issues
:) If you are nesting below the fabric and in the bobbin area... that is an upper tension problem. Tighten the upper tension... and try again.
Aug 31, 2012 | Singer 7468 Mechanical Sewing Machine
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Keeps breaking thread or thread get hung up in the bobbin area.
This is caused by any one of a number of issues. The most common ones are as follows:-
  • Using the wrong needle for the type of thread
  • Too low a top thread tension
  • too high a bottom thread tension: as this is non-adjustable it suggests an incorrectly threaded bobbin or a bobbin which is wound too tightly
  • Using poor quality non-Singer needles
  • Using poor-quality thread of the kind often found in discount stores
Sep 09, 2010 | Singer Sewing Machines
How do i fix a birdnesting problem with my singer 5050c sewing machine , or do you have instructions of how to thread the machine.
Try adjusting the tension. It sounds like the bobbin thread is too loose or the bobbin is not in correctly. Try taking the bobbin out and turning it around and putting it back. When you hold the bobbin in the fingers of your left hand and you pull the thread out with your right hand the bobbin should be turning clockwise. If the nesting persists, try ajusting the tension one way and then the other to see which seems to help. Hope this helps!
Jun 01, 2010 | Singer 5050 Mechanical Sewing Machine
My Singer 5050C wants to bunch the thread underneath
Make sure to thread machine with the presser foot raised. Then make sure thread gets in between the tension discs and that you have the machine threaded correctly with the thread going up and into the take-up arm. tension should be set at 4-5.
Oct 18, 2009 | Singer 5050 Mechanical Sewing Machine
Singer 5050 Mechanical Sewing Machine Logo
447 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
