Question about Hitachi ULTRAVISION L42V651 42 in. LCD HDTV
Lamp box is open or assembled wrong on my Hitachi Ultravision DLP 2005 model
I have a 2005 Hitachi Ultravision Digital DLP 52 in, I moved it from one room to the other and now it says the lamp box is loose, where is this located?
  • 197 Answers
It is in the front pop the front cover off, look in the owners manual
Posted on Jun 07, 2009
How does a ballast for a hitachi ultravision dlp tv look
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
Apr 20, 2016 | Hitachi Televison & Video
I need to replace the lamp on my projection tv HITACHI ULTRAVISION 53UDX10B. it's difficult to find online. i will need to have the part number for the lamp.
Your model is the DP-15 chassis which is a CRT projection so you do not have a lamp like the DLP models do. You have three CRTs Red, Blue and Green instead of a single lamp.
Jun 09, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 52" projection tv went black. when i
if this is a DLP it seems your lamp burned out and needs replaced , if so search ebay with model # for replacement, you can purchase a buld or lamp assembly
Nov 28, 2010 | Hitachi Televison & Video
How heavy is a hitachi 52 inch dlp tv
The weight of the hitachi 52 inch TV is around 94.1 lbs 0r 42.6 Kg
Thanx
Jul 31, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision 50V500A screen dim
The model indicated is a DLP rear projection and uses a "lamp" for brightness.
If it has not been changed for a while it should be on the right side of the set behind a removable plate. Check your owners manual if you have it.
Life span varies but 2,000 hours is normal.
Let me know if you need any further assistance as I am here to help.
SD TECH
May 14, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Sound, no picture, no display, just a black screen
its a Hitachi DLP
it has a lamp that illuminates the screen
it has most likely failed in your owners manuel it should be more specific and you can order a lamp and replace it your self
and you can order a lamp off of line or call hitachi
Oct 26, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
TV Exploded
Sounds like the DLP lamp failed. You can decipher the Hitachi flashing red light. That should help to be sure.
The DLP lamp replacement is fairly straightforward and can be done with minimal tools
Sep 10, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Lamp went out on DLP TV
Did you replace the lamp door? A flashing red light is an indication of a door open or an impropely seated lamp. Try removing the lamp and reseating it. Reinstall the door and try turning it on again. Also, you may want to unplug the TV from the power source, count to about 20 and then plug it back up again. This may reset the TV.
Good luck
Aug 09, 2009 | Hitachi Televison & Video
Hitachi ultravision
If it's a DLP, you can try that first.With the volume turned all the way down, in the rear of the set close to where the lamp is, (with the set on) listen to hear if there is a buzzzing sound, if there is then chances are it is the lamp. The buzzing sound you may hear is the lamp inverter power supply trying to start the lamp of which it can't.
Mar 19, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ULTRAVISION L42V651 42 in. LCD HDTV Logo
302 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
