SOURCE: Onkyo tx-sr800 PROTECT mode
Hold video1 and press speakers A button, it will say "clear" If the message protect appears again, then its service time.
SOURCE: Protection mode
I banged my head against the wall on this same issue and finally realized that my rear surround speakers were mixed. My rear right was wired to rear left because I was turning around to see L and R. It would shut off at about volume level 40, which was loud but not rumbling. It now ROCKS and is in no way a problem with heat. I have always run it with the cabinet open to allow air to circulate.
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
SOURCE: onkyo ts595 goes into protect mode with volume increase
HI check your speaker cables are not touching, also make sure "b" speakers are not on and that all your speakers are 4ohm or higher as this will cause the amp to shut down if they are to low an impedeance,The amp is protecting itself when it shuts down.
hope this helps.
CABLE GUY.
SOURCE: my onkyo receiver (tx8511) keeps going to protect
Hi there
To answer your question;
Your amplifier goes into protect mode when it detects a fault or condition that could damage the speakers and/or the output stage.
Often caused by shorted outputs.
Although this does`nt tell you much on how to fix this problem, the best help i can give you at this point is to tell you to have it looked at by a repair shop.
Hope this help good luck
