Question about Kenmore 43042 Front Load Washer
Front loader wont agitate or spin, but it fills with water and pumps water out
Hi i have a older model kenmore front loader washer the stack kind the dryer works fine ut when i turn on the washer it fills but it wont do anything i hear the timer clicking but it doesnt agitate or spin but it does punp water out can you help please,thanks chris. I have the same issue. The washer is located a vacation home and it worked 6 weeks earlier. We do have a mice problem there. I took off the back and top to see if it was just a belt issue. The belt seemed fine and the motor did not seem to move after the washer was filled with water. I did not do a diagnosis to see if the motor was getting the signal to turn on.
  • Will4urAplnc May 11, 2010
    Will the washer go in to high spin if you turn it to spin only?
  • 15,935 Answers
The timer is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: front loader wont agitate or spin, but it fills with water and pumps water out
likely the lid switch is bad - if not the ECU/timer is.
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
May 28, 2009 | Kenmore 43042 Front Load Washer
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
Kenmore stackable mod number 417.94802301
check your lid switch. if your lid swith is bad, it will fill and agitate, but will not pump or spin. therefore it will not go into rinse cycle without being able to pump out water. some lid swithes control the agitation also (usually frigidaire and older maytags), but i doubt yours does. you can check the lid switch for continuity while opening and closing the lid with a meter
Apr 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Kenmore elite washer
Assuming you have a top loader, because a front loader does not have an agitator, the spindle that holds the agitator securely in place has worn down to the poing that it won't turn. They are usually made of rubber and has grooves in it and fits into a the agitator. The grooves are worn out. Replace them from an appliance store and you should be in good shape.
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Stackable washer
ibunton. 10 loads, what some bad luck. Your model is a direct drive, so there are no belts. From your description it almost sounds like your drain pump is jammed causing the motor to kick on overload. Remove the front panel by pushing on the two clips just below the top on each end about 2 inches in. The panel will pull off. The pump sits right in front. There are two clips that hold the pump on. Remove the clips and pull the pump off. Now put the timer to the spin position and start it, see if the motor turns. If so, your pump is probabley jammed with something. If it is the pump the part number is 3363394. Easy fix, 2 clamps, 2 clips. If the pump is ok, then we'll have to dig in deeper. The attachment shows a top loader, but the pump, motor and trans are the same as your stacked unit. Catriver...post back
Jan 17, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore 43042 Front Load Washer Logo
228 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
