Question about Frigidaire 26.0 cu. ft. Side-By-Side Refrigerator with PureSource 2 Water Filtration
Intermittant water leak under Kenmore side by side onto floor
I think it leaks when the water comes on to feed the icemaker. The supply tube in the freezer that comes out of the back and into the icemaker seemed frozen so I thawed it out. I turned the water back on and waited. Sure enough it is still leaking! Water comes out in short burst with the sound of a motor triggering it. I took off the back panel and see a small (1/2 inch diameter?) PVC type hard tube that is not attached to anything. I don't see or feel anything that had fallen off. I assume that it is some sort of overflow outlet.It was wet around this but not sure if it is coming from here or from somewhere else. HELP!
    Novelist:
  • 103 Answers
Hi: Well, you have an inexpensive fix ahead. Your defrost drain is clogged. Look at the bottom of your freezer, the back wall. At the very bottom you will see a shallow funnel with a hole in the center. Usually a few slits in the metal above it for venting. This hole is not refrigerated and can also swallow a frozen pea or other morsel. Your defrost mechanism is also above it and uses it to drain the defrosted ice from the coils. Which it is not happening. Unplug and warm the freezer (put your food in a cooler) and you could pour some warm water and clorox bleach down the hole at the bottom. If it is just mold the clorox will eat it up. If its worse get a pipe cleaner (as in tobacco pipe) and work it in the hole. You have a cheap fix. Hope this helps, Jeff
Posted on Jun 01, 2009
We have a Samsung side by side. Ice maker on the top as part of frig. water is leaking and I see the ice stopper is not closing to keep the warm air from entering the ice compartment. Any ideas
If the icemaker is leaking water onto the floor:
  • Turn off the icemaker and then turn off the water supply to the icemaker. See Icemaker On/Off Switch.
  • The water supply line is usually located under the kitchen sink.
  • Locate the cold water line and look for a small 1/4" copper line attached to it. Where these two lines meet, there will be a saddle valve. This is the shut-off valve. Turn this valve in a clockwise manner until it stops. This will shut off the water to the icemaker.
Aug 11, 2017 | Samsung Refrigerators
I have water leaking from the front left corner of my Kenmore elit refigerator. I have shut off the water feed and the icemaker switch
That is probably the 5/16" poly tubing running up into the door and to the water tank. You can get tubing and unions to fix that.
May 08, 2011 | Kenmore Side by Side Refrigerator
Icicle are forming around icemaker port inside of freezer compartment drips seem to come from around inmaker feed water area.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Our kenmore side by side is leaking water into the bottom of the freezer how do I find where it is coming from and repair?
Most of the time that problem is caused by your drain hole in the freezer being blocked up with food or trash....or sometimes ice. Every 8, 10, or 12 hours depending on your defrost timer you fridge will defrost itself and drain the water under the fridge to a pan. If that drain is plugged then the water runs into the bottom of the freezer and sometimes will leak out onto the floor of your house. Another thing that it could be is the icemaker. Make sure the icemaker is not spilling water all over. If your icemaker is working ok, and there is not icecicles all over then rule out the icemaker. I would bet it's your drain.
Sep 11, 2009 | Refrigerators
106.55244400 leaking water on floor
Hello, sounds to me like you either have a leak on the nut on the water inlet valve or a pinhole leak on the inlet valve body...have come across this many times before...you may not see the leak from the valve because it is very fine spray but it's there...only real way to detect where it is coming from is to pull the valve out switch water on and see where the leak is....either this or you have a blocked drain tube in the refridge but with the info you supplied i would suggest the valve. If you have any other questions or concerns please feel free to comment again. Good Luck! Mike
Aug 17, 2009 | Refrigerators
GE side by side leaks water from icemaker tube
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaking water on floor only happens when making ice
I wonder if you just notice the noise now because the leak has you more aware? First things first. Lift up the arm on the ice maker (a few hours prior to attempting service) to stop it's operation. You need to roll the unit forward to give you access to the back. You'll see a plastic tube that runs from the bottom compartment (water valve) to the ice maker fill tube. Lower the arm of the ice maker and observe the plastic tube for the location of the leak. The most likely spot would be at the top. A hose clamp can be put on the fill tube after making sure the plastic supply tube is completely inserted into the fill tube. The fill tube is the piece that goes through the rear bulkhead and delivers the water to the icemaker. It may be neccessary to remove the icemaker to thaw out the fill tube using a hair dryer.
Apr 28, 2009 | Refrigerators
WATER PUDDLE ON FLOOR
no water will be coming from that line it is going to be a blocked drain line or a rust hole under where you can't see
Apr 17, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Frigidaire 26.0 cu. ft. Side-By-Side Refrigerator with PureSource 2 Water Filtration Logo
122 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
