Question about Roper RES7646KQ Electric Dryer
Dryer is getting Power but not coming on.
My Dryer worked one day and the next day it wouldn' even come on. The plug is not burned, the tub turns, the timer even works. There were no humming noises or sparks, it just stopped working. Help me
  • 6,784 Answers
Check the following---
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Posted on Jun 01, 2009
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
Jun 28, 2016 | LG WM3987HW Front Load Washer / Dryer
Samsung dryer without power
What is the model number??
Jun 27, 2013 | Samsung Dryers
Pontiac g6 drive the car a bit went somewhere got out came back 2 hours later all it did was turn over an wouldn't start has plenty gas left it alone for a bit try to start it it fired right up. So I...
flassed less engine power wth????????? Flashed reduced engine power ! Electronic throttle control problem ! Your best bet ,take it to a GM dealer , buick , cadillac , GMC . You do not have diagnostic test equipment or knowledge to even diagnose this.
Jul 06, 2017 | Cars & Trucks
Installed a new graphic cards for Gateway DX4710-UB801A, it works for a day, but the next day, it wouldn't turn on, the power supply is not running.
Pull the new graphics card out to see if the power supply will start up, if no change, you will need a new power supply module.
May 11, 2012 | Gateway DX4710-UB801A (L-1015700R) PC...
Our dryer gave out a burn smell like a belt had broken, and even though plugged in, it will not come on. We took it a part some and didn't see anything wrong. We only took down the front facing to see the...
Dryers have a thermal fuse... typically a ceramic assembly 2-3 inches filled with resin and wires attached...usually near the motor. This may account for the burn smell. Turn the power off and replace .
Dec 08, 2009 | Crosley CDE6000 Electric Dryer
OVERHEATING, AF CODE..... Whirlpool Cabrio WED6200SW1
Mine is doing the same thing. Whirlpool still has it under warranty but says they won't replace it. They will only repair it. They have been out 5 times now and still not fixed. It will work one time and the clothes are scorched when I took them out. Do NOT BUY WHIRLPOOL. I think we should start a civil suit against Whirlpool for replacement of all of these washers.
Apr 11, 2009 | Dryers
Leaking tub seal, slow spin cycle
It's not worth fixing!
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Jul 31, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dryer
Open dryer's cover and look that the belt is OK and in place (over the tub and the motor) Try to find out from where the burning smell comes from. Does the motor spin ? Let me know with your results and I will do my best to assist you with your problem.
Aug 02, 2007 | Amana DLE330RAW Electric Dryer
Older washer/ dryer with no power
Check to see if power cord is loose at connection inside dryer. ONLY after UNPLUGING! Held on by three screws inside.
Aug 22, 2006 | Maytag PYE2300AY Electric Dryer
Roper RES7646KQ Electric Dryer Logo
273 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
