Replaced the start switch and dryer starts when turning switch to on but when releasing switch dryer shuts off.Replaced the start switch and dryer starts when turning switch to on but when releasing switch dryer shuts off.
You can't post conmments that contain an email address.
The drum in the dryer has most likely has a belt around it that makes it turn. This belt could have broken and you hear the motor running but the drum can't turn. For more info look it up on you tube. (dryer belt replacement)
Sounds like you have a faulty start switch.
Turn off the power to the dryer, remove the switch and then check the switch with a continuity meter to see if it is faulty. If it is then replace the switch
I hope this helps
Two possibilities: 1) Least likely cause. Start button is not opening when released. Don't know how far you wish to go with this but it will require some troubleshooting. 2) Most likely cause. Motor start switch has a set of contacts that close when the dryer starts and this set of contacts "seals" around the push button. If this is the case, a new switch is in order. Switch is normally replaceable without replacing the motor. Other option is use "as is".
My Maytag Performa Oversize Capacity Dryer stopped working without a warning. It dried a load on the week-end without a problem. I put a load in on Wednesday, turned the dail to on
but there was no movement or sound.
HELP!
