Question about Acer Computers & Internet
Colling fan how to remove where to find replacementjeffcallsr@yaho0o
  • 256 Answers
There should be a large cover on the bottom of the computer in the area of the fan. Remove the cover and see if the fan is there and if you can remove it. Otherwise, you may have to disassemble the main case of the computer to get to the fan. That may be more than you want to get into. If you want to get into it, let us know. Give us more details on the computer, make, model.
By the way, BEFORE YOU BEGIN, remove the power supply plug and the battery!
Posted on Jun 01, 2009
Compaq 6735s, fan runs constantly, overheats then switches off.
Dear User,
This case, you must remove your Laptop's colling fan because it maybe have many dust and dirt so that it can rotate normally. Clean it, by silicon spray or other then return it.
Apr 23, 2011 | HP Compaq 6735s Notebook
Dear Sir, i canon image runner copier we have error E805-002 which colling fan error
hello there welcome to fixYa
the problem is with your fan inside the printer . either its not working or the fan has some obstruction to move and give it a cool down . take a blower and remove dust by cleaning it with the powerful blower and see if it again gives you the same problem . if it does if you can open the printer screws and then look for the circuit to which the fan wiring attached remove it . and replace a new fan off course if you buy the fan your self and fit it again in your printer it would cost you less , then off course the repair man or service center .
do comment if it helped you or not .
best Regards
Apr 11, 2011 | Office Equipment & Supplies
52 inch plazma tv LG keeps turning off and each time i turn it back on it turn off sooner.if i leave it offfor long time . it comes on for 3 min. then turnes off
hi,
i think ur tvs colling fan has some problem. open the back cover of ur tv and then power it on. watch is the cooling fan is working or not. normally it will be in top the left and right side. if it is not working. remove the power. then remove the fans clean it with a brush. u can see a label on the fan in which its specification are written. remove the label. and put two drops of oil in its bearing. turn the fan leafs with ur finger for some time till it runs freely. fix it back . then power on ur tv .
ok
Dec 15, 2010 | LG Televison & Video
It says fan problem poweing off and it shuts down
HI,
may be the fan inside ur tv is not functioning. because there is some parts in side ur tv which need colling, so fan is necessary. u can do the following by your self. just check it.
remove the power . just open ur tvs back cover . find out the fan. normally it may be in top left and right side .it will not runs if it is stuked because of dust inside it. remove the fans. try to rotate its leaf, it should run frely. if not clane it. remove the specifiction sticker on the fan. and put on or two drops of oil in it bearing . rotate it leafes with ur finger until it runs free, then fix it and try again. if it says fan problem again just replace the fans.
if u need any further assitence fleel free to conact me through fixya.
ok
Dec 14, 2010 | Sony 42XBR900 Television
My computer shutdown after 1 or 2 hours
unplug & remove cover and clean dust,dirt out with compressed air plug back in and try. check all cooling fans and make sure they are running if not check connections or replace with new one
Dec 18, 2008 | Biostar MCP6P-M2 Motherboard - v6.0,...
1999 Chevrolet Blazer oil pump
You must disconnect the motor mounts and remove the colling fan blade(so it won't hit the shroud) and raise the engine as high as poss, then remove the flywheel flex-plate cover and remove all the pan bolts, gently pry the pan from one side to the other until the gasket breaks loose, remove the old oil pump and reverse the procedure.
Oct 04, 2008 | 1999 Chevrolet Blazer
1995 buick lesabre colling fans not wworking
simple fuse.. . . . usually found under the steering wheel . . had that problem just last nyt. hehehe usually the aircon and aux fan have 1 fuse. .
Aug 03, 2008 | 1995 Buick LeSabre
Removing cooling fan
maybe it's a left handed nut
Jun 18, 2008 | 1999 GMC Safari
My american fridge don't appear to be cooling properly and some black stuff keeps appearing in the fridge compartment. it also keeps making rattling noise now and then!! Can you help?
my advice is check and replace the fan in the freezer or the fan blade remove the back cover where the fan is in the freezer the freezer does all the colling for the unit
May 09, 2008 | Refrigerators
Cpu colling fan
there is usually screws under the rubber foot pads.
Jan 02, 2008 | Compaq Presario M2000 Notebook
Computers & Internet Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
