Question about Maytag Atlantis MDE7400AY Electric Dryer
Dryer lint screen doesn't seal well and clogging vent
The lint screen does not seal well so a lot of lint is getting pass the screen and clogging the vent which then reduces the air flow and drying ability. I looked at a similar new Magtag dryer and see there is now a felt strip on the screen that makes a much better seal. How can I fix the original poorly designed screen?
    President:
  • 272 Answers
You can buy felt tape from a variety of sources. Here's one:http://www.findtape.com/shop/product.aspx?id=412&bc=F&setscreen=1&width=1436&height=0
I'm sure Amazon sells it as well as most Lowes and Home depot type warehouse centers.
Posted on Jun 01, 2009
NO HEAT
The most common problem with poor drying or no heat (especially with gas) is a clogged exhaust vent. Before you start blaming the dryer, clean the lint screen, put it in "air dry mode" if it has one and go out to the vent to make sure there is a strong airflow (be careful in case a hornest's nest is your problem!) If you can't get to the vent and the lint screen is on top of the dryer, pull it out. There should be a mild suction at the hole. If it's blowing out at you your vent is clogged and no gas dryer will ever run like that. Clean out or replace your vent hose, etc. Always use metal to avoid a fire hazard. If that doesn't help, make sure the gas is turned on and call a repairman, depending on your skill level.
Jul 08, 2011 | Roper RGX4634KQ Gas Dryer
Lint not catching in tray and is clogging the roof vent
This is common on all dryers. Not lint screen will catch all the lint although some are better than others. If you haven't already, you will need to clean or have your home vent cleaned (with a brush that goes all the way through the vent). If vent is not cleaned the lint will back up all the way into your dryer and cause a mess. You have stated your vent goes up to your roof so you will need to clean it every 6mths to 1yr. Aside from this there is no fix that I am aware of. Please rate me after reading this.
Dec 14, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
Dryer is not drying. Lint is not collecting on
There is no lint screen that catches ALL the dryer lint. Some lint will always get exhausted through the dryer vent exhaust ducting along with the moisture from your clothing as it dries. If the exhaust vent remains unobstructed, all the air and lint will be blown out the end of the dryer vent exhaust.
However, if the air meets any resistance from kinks, excessive bends, or sags, moisture will build up inside the dryer vent exhaust causing the lint to stick to the interior walls of the vent hose. Over time this lint builds up and forms a clog. With a clog comes condensation and longer dry times. The dryer will continue to run inefficiently and cause the heating circuits to work harder and overheat. This will eventually lead to a failure of the heating circuits. If you are seeing condensation inside the dryer, it is strongly recommended the you inspect and clean the dryer exhaust vent hose. You should repeat this a couple of times a year to ensure it remains obstruction free.
The most frequent causes of dryer vent clogs comes from the following:
1. Ducting that runs in an upward direction in homes that have an attic exhaust. This is a stupid design that gravity will always win. When the dryer shuts offf, anything left in the vent will fall down the ducting to the base of the wall and accumulate. Over time, this forms a clog.
2. Ducting that runs under the home in a crawl space. If not correctly hung from the rafters, the ducting will develop sags causing choke points where lint can accumulate. Leaving it on the ground is not the answer, either. This gives opportunity for rodents to possibly chew through it. This will cause leaks which exhausts warm moist air under your home resulting in mold and mildew.
3. Using plastic dryer vent hose. This type of hose is not recommended because it kinks easily and can get crushed, causing an obstruction where lint can clog. Rodents can also chew through it easily. Pushing the dryer up against the wall and crushing the hose is a common cause. Use the semi-rigid metal type ducting that resists crushing, kinks and rodent infestation.
4. Rodents. Mice love lint. If given the access to it, they will build inside the dryer vent hose which provides a nice warm place to live with lots of bedding material. Make sure you exhaust vent on the exterior of your home is about 12 inches from the ground.
5. Exhaust vent screens. I know there are many types of exhaust vents on the market that you can purchase that have screens on them to prevent birds and rodents from entering them. The screen can actually become and obstruction, though. The smaller the opening, the more resistance the blower fan meets and lint will clog at the end of the exhaust. If you chose to use a protected exhaust vent, the ones with louvers work better. You will still need to periodically check the ensure it does not become clogged.
6. Excessively long vent hose. The rule of thumb when it comes to dryer vent ducting is: The SHORTER and STRAIGHTER the run, the BETTER. Excessively long dryer vent hoses will clog due to the fact that the blower fan is not able to push all the air and lint all the way to the exhaust.
7. Kinked, Excessively Bent, or Crushed vent hoses. If the vent has any choke points due to kinks, bends, or gets crushed behind the dryer, you will develop ponts where the exhaust vent will clog.
The following link may also help in providing some basic guidance on how to install dryer vent hose:
http://www.fixya.com/support/r389357-dryer_ducting_installation_tips
I know it may seem that I'm beating this point to death, but it is important to provide good air flow for your dryer. The number one cause of dryer failures and house fires comes from poorly maintained and poorly installed ventilation ducting.
If you have any questions, please let me know. I hope you find this information helpful.
Sep 07, 2009 | Dryers
Dryer is emitting dryer dust during dry cycle. Vent is not clogged and vent screen is cleaned after each dry cycle. Lots of dust escaping the system during dry cycle.
You've got a hole in the 4" tubing that connects the dryer to the outside vent. Airflow in the dryer is a closed system and the only way lint can escape is if there's a hole somewhere. The vent hose is by far the most likely source of your lint problem.
Aug 21, 2009 | Dryers
The lint screen does not capture lint. The lint
To dispell a common myth. There is no lint screen that catches ALL the dryer lint. Some lint will always get exhausted through the dryer vent exhaust ducting along with the moisture from your clothing as it dries. If the exhaust vent remains unobstructed, all the air and lint will be blown out the end of the dryer vent exhaust. However, if the air meets any resistance from kinks, excessive bends, or sags, moisture will build up inside the dryer vent exhaust causing the lint to stick to the interior walls of the vent hose. Over time this lint builds up and forms a clog. It is strongly recommended to have the exhaust vent hose checked and/or cleaned a couple of times a year to ensure it remains obstruction free.
5. Exhaust vent screens. I know there are many types of exhaust vents on the market that you can purchase that have screens on them to prevent birds and rodents from entering them. The screen can actually become and obstruction, though. The smaller the opening, the more resistance the blower fan meets and lint will clog at the end of the exhaust. If you chose to use a protected exhaust vent, the ones with louvers work better. You will still need to periodically check the ensure it does not becoe clogged.
If you have any questions, pleae let me know. I hope you find this information helpful.
Aug 19, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer vent pipe has condensation issues.
With all of that condensation I'd be suprised if your clothes were getting dry at all. A lot of times cleaning the dryer vent is not enough. It sounds like your vent is really long. Long vent lines have a large potential for lint clogging. Check the airflow at the end of the vent at the side of the house. Your'e probably getting very little. For a run like that we always attach a electric leaf blower to the dryer side of the hose and let it run wide open for about 5 minutes. This should help to break up any clogged up lint. You can check your results at the end of the line on the ground. If it doesn't do much you may want to consider replacing the vent hose. Hope this helps.. Thanks
Feb 18, 2009 | Whirlpool Dryers
Electric dryer keeps shutting off...
Be sure that there is a LOT of air coming out outdoors first. If there is, the hi limit thermostat is now defective from the abuse of your fire hazard, I mean clogged vent. (same thing) If not, the vent is still not clean enough. If it's flexible duct, replace it with solid duct. You could also have a clogged up lint screen, (fabric softeners commonly clog the screen) or the fan in the dryer may also be clogged up.
Jul 02, 2017 | Kenmore 64852 Electric Dryer
A lot of lint is getting by the in unit filter screen and is cloging the outside vent bird screen The dryer is about one year old and is a model DHDVH52
Check the seal for the dryer vent coming from the drum itself. It may just be a simple lint filter replacement that is realitively cheap and can be bought from www.marcone.com. If it is a top removable lint filter, the seals get worn out quite easily. Also, be sure to clean the lint filter after EACH load to help prevent it.
Mar 15, 2008 | Dryers
Kenmore 110.72512101 gas dryer
Are you getting little or no lint on the lint screen? Are the clothes coming out nearly as wet as they went in, but feel warm? If so, you probably have a blockage somewhere in the vent/duct. Don't just check the back of the dryer, but also check the duct thru the wall and the point where it exits the house (exterior wall or roof). Many times birds will nest in the exterior vents or if they have a screen to keep the birds out it may become clogged with lint. If you have a window nearby try drying a load with the vent hose disconnected from the wall and hang it out the window (you COULD vent it into the house, but you may end up with lint everywhere and a lot of moisture in your house).
Jan 02, 2008 | Kenmore 75944 Gas Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
444 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
