Question about Nintendogs: Dalmatian & Friends for DS
Top half dont work
My top half of my ds dont work and i need it to play
  • 32 Answers
Solution:
1. IF you have R4 card in your DS, take it out.
2. Go to Settings (Little icon on the bottom of the touch screen)
3. Select Pink button
4. Select "GBA Mode" (pink button on the right)
5. Select "Touch screen"
NOTE:
This is mainly affective for GBA games, not DS games unfortunately.
If you are really that desperate to play DS games properly, then either hope you can still claim it on warranty and/or buy a brand new DS (maybe even the new DSi).
Hope I helped
- donman92
Posted on Jun 04, 2009
My top screen on the ds i have started to go white a while back. it kept getting worse and now i have to continuosly bending the cover back and forth for it to work for mabey 5 minutes. any ideas so i dont...
This is due to a faulty ribbon cable which runs from the bottom half of the ds to the top half via the hinge. Unfortunately the only way to solve this is to purchase a new top lcd screen :(
Jul 28, 2010 | Nintendo DS Lite Console
How do I replace a DS Lite top screen? Any special tools needed? Thanks.
You have to take the whole ds apart to replace the top screen its not the easiest one of the screens to replace.
I'll start assuming you have dissasembled the bottem half of the ds but it is still attached. Once the logic board and bottem screen have been removed you are left with just the plastic where the buttons are, still looking at the ds as if you looking at the back of it, on the top left you will see two screws these have to be undone, you will need a small philips screw driver, once undone the two pieces should come apart, becarefull of the wires on the right, thread them back through the hole, and there is a slight cut in the plastic allowing you to thread the ribbon cable out as well.
When you have just the top half, turn it so the speakers are facing you as if you playing on it, there are four philips screws to undo, but they are coverd by small rubber gromets, you will have to prise them out using somthing pointed like the end of a stanley blade, becareful not to scratch the plastic. Once the screws are all out hold with both hands with your thumbs where the speakers are, apply a bit of presure in a downward and towards you motion the two parts should slide away from each other, you will see a gap at the top, turn the whole thing over again and lift the top half up and away from you exposeing the top screen and speakers, attached to the black wire is the wirless receiver which you dont need to touch and the white wire is the mic. Thread the ribbon cable back through the hinge by rolling it up and it should go through. You will need to desolder the speakers from the ribbon cable attached to the screen(ensure u note which way the wires are soldered so you can resolder them on properly to the new screen). Once thats done put it all back together the way you took it apart.
There is videos on how to do this in more detail on youtube just do a search and you will find what you are looking for.
Tools needed:
Tri-wing screw driver
Small philips screw driver or pozy drive
Pointed object(stanley blade)
Pair of twizzers
Hope this helps. post back if you have problems and ill try to run you through them.
Jan 29, 2010 | Nintendo DS Lite
DS Lite Top screen Froze image
Sounds like your screen may have come loose, OR its time for a new one. Either: A) Send it in for repair. (Big N may charge up to 80$ if its not within warranty)
B) Buy parts from a place like DealExtreme (http://snipurl.com/hf0li) or some place similar, but that means opening it and you'd need a Trigram/Tri-wing screwdriver to open it as well. Not good for the inexperienced, though as there's a good chance of bending the paper thin screen wires. (but I guess the experience of knowing you can do it yourself(~25$), as well as for less is better than having to shell out ~80$ for Big N to fix it.)
C) New DSL?
Aug 10, 2009 | Nintendo DS Lite Console
My ds just crashes--shuts down--when playing. Is
The same thing happened to my DS that was 3 years old. But at a point it didn't even turn on. The top screen made a quick blink then it turned back off automatically. I suggest you just get a new DS (I got a DSi) because a new battery is VERY expensive.
Answer:It is definitely the battery, though.
Jul 07, 2009 | Nintendo DS Lite Console
My top screen is busted.
its is possible but you would get the display of tha half game or u would have starting problems with some games
Jul 05, 2009 | Nintendo DS Console
The top screen is blank lower screen good
well maybe the game ur playin just has to only use the lower dont worry some games are like that . half my games only use the top screan and the other half use the bottem only
Feb 17, 2009 | Nintendo DS Lite Console
Nintendo DS start up menu disappeared.
take out all of the games in the ds then the menu should come up then click the little ds picture at the bottom. that will take you to another menu. click on the wrench in the pink box, then click the top box which has an arrow pointing into a box. click the top box which says manual mode then press confirm. the ds will go off then when you turn it on it should go to the menu even with a game in. hope this helps! =)
Dec 08, 2008 | Nintendo Pokemon Diamond for DS
Ds lite games not playing?
have you tried taking the game out and in about 10 times when the ds is turned of
Sep 08, 2008 | Nintendo DS Console
Ds top screen half normal half green tint
i had the same problem  but it was blue tint shortly after the ds would turn on flash then turn off turned out to be the wire ribbon to top screen:: needed new top screen!!
Oct 22, 2007 | Nintendo DS Lite Console
Lights on bottom screen don't light
i dont think it is a problem i think it just does it to save energy
Oct 03, 2007 | Nintendo DS Lite Console
Nintendogs: Dalmatian & Friends for DS Logo
113 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
