Question about Kenmore Washing Machines
Water won't run into washer - clicking sound only front upper left like plastic gears running over each other
Kenmore elite HE3 front load - 1.5 yrs old, water won't run into washer, clicking sound in the front upper left (facing washer) like plastic gears are running over each other.
  • 15,935 Answers
The fill valve is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
My kenmore elite HE3 fills up with water when it is not running.
Hi... if your Washer is filling and its not running... you need a new water valve
Mar 30, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 will not spin, sounds like slight gear slipping
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 09, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front loading washer, model 110.45872400 - completely drains and runs correctly but sometimes an hour later there will be water in the tub
Your water inlet valve is leaking it needs to be replaced.You need to remove the top to access it.There are screws along the back edge holding it on.
Jul 24, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite dryer runs cold no heat
Most of the time its the thermal fuse part # 3390719
Jul 21, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 will not hold water leaks into the pedestal
run you fingers into the door boot and inspect for holes ,, that probably what it is ,,,,,,big tear
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
HE3 Washer just keeps beeping at me when I push the start button
Bad motor pump and it's a common problem kenmore elite front load washer so we need to left the washer from the front and get under the washer to get the motor pump replaced
Nov 05, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite front load washer - wont drain and loud clicking sound from bottom
Yes...sounds like you may have something lodged in the drain pump impeller. The following link explains how to check the drain pump on this washer for obstructions:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
It does not take much to damage the drain pump on this washer. If something has been lodged in the pump for any significant period of time, the pump may be damaged and required replacement. The may still run, but may not be pumping water as it should. You may experience an error code as well. On HE3 models, the error code is "F02" or "SUD". On HE5 models, I believe it is an "F21" error. Replacement pumps can be ordered on line at searspartsdirect.com.
If you find that you need to replace your pump, I have this additonal link, that provides step-by-step instructions:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
Please read the note at the bottom of the link, as it IS possible for a pump to still run and not pump water. I hope you find this information helpful. Let me know if you require additional assistance.
Sep 16, 2008 | Washing Machines
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
67 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
