2006 Chevrolet HHR Logo
r
robert owen Posted on Jan 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you perform a learn after installing the igniton relay on a 2007 hhr 2.2
Joe Taylor
Level 3:
  • Chevrolet Master 2,229 Answers
  • Posted on Jan 23, 2014
Joe Taylor
Chevrolet Master
Level 3:
Answers
2229
Questions
12
Helped
908512
Points
6395
30 MINUTE RELEARN PROCEDURE
  1. Turn ON the ignition, with the engine OFF.
  2. Attempt to start the engine, then release the key to ON, vehicle will not start.
  3. Observe the SECURITY telltale. After approximately 10 minutes, the telltale will turn OFF.
  4. Turn OFF the ignition, and wait 5 seconds.
  5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes. The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
  6. Important: The vehicle learns the password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
  7. Start the engine. The vehicle has now relearned
2007 Chevy HHR LT 2.2. Replace fuse box housing.
Replace a Fuse: 2007 Chevrolet HHR LT 2.2L 4 Cyl. (carcarekiosk.com) This has a video showing location of the engine fuse box.
Auto Parts by CarParts.com - Right Parts. Right Now.
Chevrolet HHR Repair & Service Manuals (35 PDF's (onlymanuals.com)
To replace the fuse box housing in your 2007 Chevy HHR LT 2.2, follow these steps:
Locate the Fuse Box: The fuse box is typically located in the engine compartment or under the hood. It houses various fuses and relays that control different electrical components in your vehicle.
Disconnect the Battery: Before working on any electrical components, disconnect the negative terminal of the battery to ensure safety.
Remove the Cover: Open the fuse box cover. You'll find a diagram inside the cover that shows the location and function of each fuse.
Identify the Faulty Fuse Box: Inspect the fuse box for any signs of damage or wear. If it's cracked, corroded, or malfunctioning, you'll need to replace it.
Unplug Electrical Connectors: Carefully unplug the electrical connectors attached to the fuse box. Take note of their positions to reconnect them correctly later.
Remove the Old Fuse Box: Unscrew or unclip the fuse box from its mounting bracket. Gently pull it out.
Install the New Fuse Box: Position the new fuse box in place and secure it to the mounting bracket. Reattach the electrical connectors.
Replace Fuses: Transfer the fuses from the old box to the new one. Make sure they match the correct positions as indicated by the diagram.
Test the Electrical Systems: Reconnect the battery and test all electrical systems (lights, radio, etc.) to ensure everything is functioning properly.
Secure the Cover: Close the fuse box cover and secure it in place.
Remember to consult your vehicle's manual or seek professional assistance if you encounter any difficulties during the process.
2answers
2010 Chevrolet HHR Wagon. Replacing windshield washer pump in HHR 2010 please.
Question edited for clarity, add maker, put it first.
Question moved from Misc to year make model category.
Videos in the link, and links to suppliers
https://www.google.com/search?q=hhr+2010+replace+windshield+washer+pump
2007. How can I install blower motor resistor?
WELL IT UNSCREWS AND COMES OFF.
MY GUESS IS, NO TO FIND IT. IS THE QUESTION.?
BLOWER FAILS ON HIGH OR NOT? IS FIRST.
FAILS ALL SPEEDS IT IS NOT THIS RESITOR BLOCKS FAULT
2007 Chevrolet HHR?????
CARS COME WITH 2 KINDS OF HVAC.
MANUAL OR CLIMATE CONTROLS. (FANCY)
AS SHAME REALLY POSTING HUNT
AND NOT SAYING BLOWER FAILS ON HIGH, AND MUST NOT.
ON HIGH THE BLOWER MOTOR DC, PIN MINUS IS GROUNDED
SOLID, AND MUST BLOW EVEN WITH RESISTOR MISSING!
SEE HOW THAT WORKS THE SERVICE MANUAL COVERS ALL THIS ,READ IT?
LETS SAY HIGH FAILS. (THE HARDER JOB.)
THAT MEANS HVAC RELAY BLOWN
OR BCM3 FUSE BLOWN, 30AMPS.
OR BCM IS NOT HAPPY, SCAN THE CARS OBD2 PORT AND IT TELLS YOU WHY BCM IS NOT HAPPY IT WILL ,SO WHY NOT.?
ONE MORE OF MANY FAILURE MODES
SAY BLOWER FAILS ONLY ON LOW. OR ANY LOW SPEED.
THE RESISTOR IS BAD.
THE BLOWER MOTOR FAN MUST BLOW ON TO THE RESISTOR OR IT BURNS UP.
SO IS LOCATED ON ALL CARS RIGHT THERE.
AT THE FAN. BLADE OUTPUT PORTS.
IF THE MANUAL SYSTEM HERE IT IS
@#2 BINGO , #3 IS DC MOTOR
How to change fuel filtrer on 2007 chevy hhr
https://www.autozone.com/repairguides/HHR-2006-2008/Fuel-Filter/Removal-Installation/_/P-0996b43f80cb2e21
https://www.bangshift.com/forum/forum/bangshift/tech-section/12586-fuel-filter-hhr
https://www.chevyhhr.net/forums/general-hhr-4/hhr-fuel-filter-replacement-59030/
https://www.chevyhhr.net/forums/how-tutorial-library-21/fuel-pump-replacement-36541/
It is built into the pump.
How do I remove tank?
Fuel Pump Replacement - Chevy HHR Network
www.chevyhhr.net/forums/how-tutorial.../fuel-pump-replacement-36541...
Jul 13, 2011 - I secured the front tires and started removing the electrical wires, connectors and the main fuel line to the tank. ... As you can see here this where the fuel enters the tank. ... I really didn't want to do this but my mechanic was moving to a new ... LT 1,Tinted windows, Alpine CDA 105, Alpine door speakers, ... I replaced my coolant. Did I make it correctly?
Apr 5, 2012
Check Engine Light for a busted fuel cap? Rip Off?
Apr 29, 2009
Do I need a locking gas cap?
May 5, 2008
why no in-line fuel filter?
Apr 9, 2008
More results from www.chevyhhr.net
AA106 - 2007 Chevrolet HHR 2.4L Auto 77k - YouTube
? 2:18
https://www.youtube.com/watch?v=umTImuWr2k4
Jan 28, 2013 - Uploaded by eallauto
AA106 - 2007 Chevrolet HHR 2.4L Auto 77k .... 2007 ChevyTrailblazer Fuel Pump Gas Tank Remove Replace - Duration: 19:08. by Neatus ...
How to Replace a Fuel Pump : Removing Fuel Tank to ...
? 2:03
https://www.youtube.com/watch?v=FEYYU6lnwWQ
Oct 1, 2008 - Uploaded by expertvillage
Learn about the steps for replacing the fuel pump in the gas tankof your ... He is able to do brake repair and tune-ups, including engine .... Chevy Silverado Fuel Pump Replace In Under 1 Hour - Duration: 22:31. by The Car Doctor 3,216 views ... GMC Jimmy \Chevy Blazer Fuel Tank Removal -Fuel Pump ...
2008 Chevrolet Cobalt - YouTube
How to relearn throttle body on a Lexus is250
Pedal Relearn Procedure
Accerlerator Pedal Released Postion Learning is and operation to learnicon1.png the full released postions of the accerlerator pedal by monitoring the accelerator pedal sensor output signal. It must be performed each time harness connector of accelearator pedal postion sensor or ECM is disconnected.
1. Make Sure the acceleartor Pedal is fully released
2. Turn Ignition switchON and wait at least 2 Seconds.
3. Turn ignition switchOFF and wait at least 10 Seconds
4. Turn Ignition switchON and wait at least 2 seconds.
5. Turn Ignition switchoff and wait at least 10 seconds
Throttle Valve Relearn
Throttle ValveClosed Postion Learningicon1.png is to learn the fully closed postion of the throttle valveby monitoring the throttle position sensor output signal. It must be performed each time harness of
electric throttle control actuator or ECM is disconnect.
1.Make sure accelerator pedal is fully released.
2. Turn ignition ON
3. Turn igntion switch OFF and wait at least 10 seconds. Make sure that the throttle valvemoves during the 10 seconds by confrming the operating sound.
(You can hear the TB sound when you have key on and shifter in first gear and step on the gas. So you know what you listening for.)
Idle Air Volume Relearn Procedure
The Following Condtions Must be met in order for procedure to Work.
Battery Voltage :More than 12.9 volts at idle
Engine Coolant Temp 158-203 degrees Farenhiet
Electric Load Switch OFF i.e Air Condition, headlamps , rear defogger
Steering Wheel: Neutral Postion (Straight Ahead)
PNP Switch: OFF (Park Neutral Switch i.e. Clutch Switch...pretty sure)
1. Perform ACCERLEARATOR PEDAL RELEASED POSTIONS LEARNING
2. Perform THROTTLE VALVECLOSED POSITION LEARNING
3. Start engine and warm it up to operation temperature
4. Turn igniton switch OFF and wait at least 10 seconds
5. Confirm Gas Pedalif fully realeased, then turn igniton switch ON and wait 3 seconds
6. Fully step on and release gas pedal5 time within 5 seconds
8. Wait 7 seconds and fully step on gas and stay on until MIL stops blinking and is steady.
9. Fully release the Gas pedalwithin 3 seconds after the MIL has turned ON steady.
10. Start engine imediatly and let idle. Wait 20 seconds.
2answers
1helpful
2006 hhr to take out ignition switch out
Removal & Installation
1. Disable the SIR system.
Remove the Instrument Panel (I/P) center trim panel by releasing the retaining fasteners
  1. Remove the Instrument Panel (I/P) center trim panel (1) by pulling out on the trim panel in order to release the retaining fasteners (2).
  2. Disconnect the electrical connectors on the Instrument Panel (I/P) center trim panel (1).
Remove the steering column opening filler assembly, with clip, & bumper
3. Remove the steering column opening filler assembly (1) by pulling away the clips (2).
4. Disconnect the electrical connector for the trunk release.
Remove the Instrument Panel (I/P) left side trim panel
  1. Remove the Instrument Panel (I/P) left side trim panel (1).
  2. Tilt the steering wheel up.
  3. Disconnect the I/P dimmer switch and, if equipped, the fog lamp switch.
Remove the 4 bezel screws (2) & the Instrument Panel (I/P) cluster bezel assembly (1)
  1. Tilt the steering wheel down.
  2. Remove the 4 instrument panel cluster bezel screws.
  3. Remove the instrument panel cluster bezel.
Remove the steering column trim covers: steering column upper cover assembly, steering column left cover assembly, & steering column right cover assembly
  • Remove the 3 cover screws (4).
  • Remove the steering column upper cover assembly (1).
  • Remove the steering column left cover assembly (2).
  • Remove the steering column right cover assembly (3).
Removal of the ignition switch
    1. Disconnect the ignition switch harness connector.
    1. WARNING
    The ignition switch must be in the run position during removal in order to avoid damage to the ignition switch.
    1. Turn the ignition switch to the run position.
    2. Remove the ignition switch screws.
    3. Remove the ignition switch from the steering column.
    To install:
    1. Install the ignition switch and screws on to the steering column. Tighten the screws to 17 inch lbs. (2 Nm).
    2. Connect the ignition switch harness connector.
    3. Installation is the reverse of removal procedure.
    4. Tighten the trim cover screws to 17 inch lbs. (2 Nm)
    5. Tighten the 4 instrument panel cluster bezel screws to 19 inch lbs. (2 Nm)
    6. Enable the SIR system. Refer to Air Bag (Supplemental Restraint System), arming the system.
      NOTE If the ignition switch is replaced and a learn procedure is not performed, the engine will crank but not start or will start and stall immediately.
    7. Perform the vehicle theft deterrent system learn procedure.
    Top Chevrolet Experts
    ZJ Limited
    ZJ Limited
    john h
    Thomas Perkins
    Thomas Perkins
    Are you a Chevrolet Expert? Answer questions, earn points and help others
