Question about Compaq Presario Notebook
My screen is black after I long into Windows
After I log in my screen remains black and all that comes up is the cursor. It cant shut it down so I take out the battery and unplug the charger so it will shut off. I have tried restarting it in each safe mode option and normally but it keeps giving me the same thing. I don't know what else to do.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    If you still get a black screen with just a cursor trying to go into safe mode as well as normally trying to get into windows then the operating system is corrupt and you'll need to restore your notebook back to factory defaults.
    Most presario notebooks have an internal restore and it can be accessed normally by pressing F11 as soon as you turn on the laptop.
    If you can't access it that way then use the recovery cd's if you get any with your laptop.
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
Acer aspire 5520
try f8 at the logo screen then disable automatic restart on system failure from the menu to find out what the error is
Jul 15, 2017 | Computers & Internet
Cant log into windows. screen black
If you have a function button try holding it down and pressing F2, possibly the screen has been accidentally switched off.
Apr 15, 2013 | HP Compaq Presario V2000 Notebook
Hi, I have a problem with my laptop(2 yrs old). When I turn it on, it shows the microsoft loading screen with the logo and all, but after that the computer screen turns black-- not completely black, but a...
Sounds like a software error. When the screen has been blaxk for a minute or two try hitting control+alt+del and use the task manager to start the process explorer.exe if so then there is a registry or windows error and needs to be repaired.
Oct 23, 2010 | Sony VAIO VGN-C140G/B Notebook
Too many! Where do I start.... 1. The Wifi connection does not work, although blutooth is on and the blue indicator light is illuminated. 2. When the pc is idle for some time, the screensaver does not...
This can happen when there is two problems.. One the computer might have been affected by virus.. Or the other thing might be the OS corrupted.. Try to get into safe mode and check if the system is working fine.. If it works well there try to do a system restore to a place wr it was working well.. If in safe mode also it doesnt work well then go ahead and reinstall the OS...
Sep 24, 2010 | Computers & Internet
Black screen with cursor won't go any further
Start the Acer in Safe Mode. Let it settle on the desktop, so that it is ready to be used. Then check the screen's settings, using right-click on a blank spot on the desktop. See if you can get it out of the limited video mode in which it seems to be now.
Or simply shut it down again, and restart back into normal mode.
Frequently, this is all it takes to reset the video.
Good luck,
-a.
May 22, 2009 | Computers & Internet
Computer won't boot Windows Vista. Screen goes black with cursor arrow.
In this case you have to do the PC restore . you can do that in dell machines by shutting down the machine and when it is coming back on just HOLD DOWN THE CTRL ket and the START HITTING f11 key in this case you will lose the data which you have the on the c drive but this issue will get resolved .
Else you can try to restart in the safe mode with networking and then go to the system restore and then select the bold dates in which you have idea you system was working fine . selct the date and then do the system restore . In this case you will not lose the data but you will lose the updates which you have done after that date .
in both the cases system will work .
Mar 25, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Logon
Go into your BIOS
Set the 1st Boot device preference to CD
Insert your windows XP disk
Boot from CD
Run XP Repair
You do this at your own risk. I am in no way accountable for damage to your computer.
Give me a message if you need further assistance
Blazamane
Jan 07, 2009 | Computers & Internet
Compaq Presario Notebook Logo
61 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
