Question about Casio G''zOne Type S Cellular Phone
Broken battery locking screw
Locking screw for battery broke on my G'Z one. Can anyone tell me where to get a new one?
    Brigadier General:
  • 7,752 Answers
You will need to take it to any mobile repair center
Posted on Jun 01, 2009
How can I repair a broken ribbon locking connector?
A spot of glue from a glue stick might work.
Jun 29, 2016 | Samsung Galaxy Tab 2
I was taking off the water pump and the two bottom bolts the head broke off was still able to get water pump off but cant get the bolt out wont turn camt put new one on till they come out help 2001...
if the bolt is accessible try locking a mole wrench on to it.
spray it with WD 40. tap the broken end with a hammer to break any
corrosion. If broken flush you will need screw extractors and
a fair amount of skill to drill a concentric hole o the broken bolt.
it HAS to be spot on, get skilled help if needed
Oct 27, 2014 | Cars & Trucks
Auto clutch adjuster screwnis broke and siezed to
will need renewed parts , can't repair siezed and broken screws etc , if the clutch is slipping and the auto adjuster has failed i'd expect needs new clutch as well , whats the mileage , service history etc ?
Oct 18, 2014 | Cars & Trucks
Broken plastic base for CBL25
FIXYA does not know who might have a broken JUG .
Dec 03, 2017 | Breville CBL25 Moda Bar Work Top Blender
Mazda 2 (2004) central locking and alarm fault. My
how can i find central locking in mazda premacy tell me plsss
Oct 01, 2013 | Mazda Cars & Trucks
The locking pad broke on my Ryobi RTS 30 table saw
Turn the saw on its side so you can access the inside of the enclosure easily.
Then remove the locknut from the mainshaft to the locking lever. This will allow you to raise the lock lever enough to get a hexkey into the screw that holds the lock lever onto the shaft, so you can remove the lever.
You have to remove the mainshaft completely, which unscrews from a secondary nut below the spring. Should be able to just apply pressure to this nut with a screwdriver while you remove the shaft.
Through the new washer, reinstall the shaft and reverse the disassembly process.
Kind of trial and error to determine how far to screw the mainshaft back in. Too far and the lock lever binds. Not far enough, and you won't get enough locking pressure.
In all, not a terrible job to tackle. Just a little frustrating- first that the washer broke at all, and second, that such a vulnerable part is so complicated to fix.
Nov 30, 2011 | Saws
The front passenger door will not open with the outside door handle or the interior door handle. after taking the inside door cover off, i discovered the interior door handle is broken and the connector...
The locking mechanism is manufactured with carbon composite and plastic levers that the door handles attach to. It is hard to tell what parts that you do need. Remove the passenger side door panel. It will have some screws and maybe a bolt on the inside handle. The panel has snap plug on it and they fit into designated hole in the door. After getting the door panel off, be careful here, there are sharp metal edges that can cut. There are some peep hole to see the rods and connector inside the door. If the plastic hooks on the door locking mechanism are broken. The hole door lock assembly will need to be replaced.
Try your local wrecking yards and tell them what type of vehicle you have and year. Also, state what door it is and what you will need.
Now, if the interior door hand hook on the lock mechanism isn't broke off. The get a cloths hanger and straighten it out and attach it to the opening latch on locking mechanism. This will give you inside temporary handle, while you are trying to fix the door. Safety. GB...stewbison
Sep 06, 2011 | Nissan Sentra Cars & Trucks
Broken locking ring on Quantaray 28-90mm. 1:3.5-5.6
Hey Quiltzlady,
If you were an authorized service technician you could probably order this part from the manufacturer, and if this camera is really only $90 to purchase new it is very likely the cost of the repair would not be worth doing. The suggestion to super glue the ring back together might work but I would try epoxy being that it is a lot stronger, but remember you run the risk of rendering the lens inoperable when you involve glue with something that relies on moving parts to operate properly. Another suggestion is to find the same lens, but broken, for sale that this ring is not broken on, and use that lens as a parts lens I hope this helps.
Sincerely,
Allan
Go Ahead. Use Us.
May 20, 2008 | Quantaray 28-90mm F3.5-5.6 Autofocus Zoom...
My needle broke, and i don't know how to replace it.
There should ba a screw that can be loosened enuf to remove broken needle. Be sure to replace new needle with flat side in the same way as the old one, otherwise thread will keep breaking.
Feb 04, 2007 | Brother XL-2230 Mechanical Sewing Machine
Casio G''zOne Type S Cellular Phone Logo
247 people viewed this question
Top Casio Cell Phones Experts
Computer Repairing
Computer Repairing
Oloyede Monsuru
Are you a Casio Cell Phone Expert? Answer questions, earn points and help others
