Question about Sanyo HT27546 TV
Can get power but no picture or sound
A drop of water got inside the tv then it quiet working. gets power but no pic or sound
  • 378 Answers
Is your Tv Raster is there? if not probably your Horizontal section of tv not functioning. Check the B+ first.
Posted on Jun 01, 2009
Has power no pic /no sound
Probably the power supply has failed. The power indicator merely shows that power is getting to your TV, not what is not happening inside.
Dec 16, 2013 | Dynex Televison & Video
I have a 47 lg lcd tv bought in 09. When i use hdmi for xbox 360 i get picture and sound but with ps3 no pic no sound. I just bought a sony bluray and get pic but no sound. I bought a lg bluray and get no...
To clarify, your TV is working correctly, since you get sound and video from all devices - Only your PS3 has no sound or video?
If your PS3 was previously used with regular AV cables (Red/White/Yellow) then you most likely need to do a PS3 video reset t output video over HDMI.
With the PS3 OFF, press and continue holding the power button until it turns on, beeps twice, and then turns back off. Do not release the power button during this process.
You may have to try the video reset a few times if it doesn't work right away.
After video reset, you should get sound and video over HDMI.
Nov 08, 2017 | LG 47LF11 LCD TV
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
NO PICTURE OR NO SOUND it just black
power supply not working -- did you check internal fuses on board --? if everything checks alright - replace the power supply board
Mar 02, 2009 | Televison & Video
Power comes on, but no picture!
sounds to me like your going to need to open it up and have a look see if there is any dry joints this is where solder joints dry up and lose contact with the main boards inside this happens to alot of older things ie like the megadrive or an old tv,
if you get your self a magnifying glass a brite torch go around the area inside the megadrive where the logo is on the front you might find a dry joint on one or more componets inside
if your not sure just re solder any joints you can see this should make it work again GOODLUCK
Feb 04, 2009 | Sega Genesis Console
TOSHIBA TV NO SOUND NO PICTURE, POWER LIGHT IS ON
the lamp in the projector might have went. try replaceing it. to do so try
ADTECH SYSTEMS they may help
there in mass.
call David Crepeau at 978 261 1087 tell him Ryan Bolduk sent you
depending where you live. They maybe able to send someone out from there sub company
Sep 18, 2008 | Toshiba 42H81 42" Rear Projection...
Emerson Quiet Kool Drips Water into the house
depends on the unit. you will probably have to slide it out of its case and clean the outside part . there should be a hose that goes from the inside to the outside for the water to go out. this hose may be clogged, trapping the water inside. as i always say a picture of the unit always helps so i can identify it and tell you what to do to try and fix the problem. email the pics to eyg2181@yahoo.com
Jul 31, 2007 | Emerson Quiet Kool 14LW22K Air Conditioner
Sanyo HT27546 TV Logo
95 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
