Question about Whirlpool ET8MHK Top Freezer Refrigerator
Water leaks inside refrigerator also the temperture is warm and the freezer is in hyperdrive.
  • bigman812 Jun 06, 2009
    The freeze has frost building, but the refrigerator is cool not cold.
  • 159 Answers
That sound like low gas in the system because the freezer is working but the fridge not
Posted on Jun 01, 2009
  • shaun greyvensteyn Jun 08, 2009
    if the motor does not switch off at all it means that the gas isnt enough in the system that is why the freezer is building frost up and the fridge is cold but not cold enough
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
Water do not get cold it stay room temperture and stay warm.
Its faulty compressor if freezer section is also not cooling.
But if freezer section is working fine,then problem is confirm defrost assembly.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Water leaking into bottom of refrigerator section
Make sure you dry everything in the freezer when you have the door open and remove ice. It won't be a leak it will simply be the warm air inside the freezer that has turned into condensation. Double check the seal around the door to see if it curled up as that could be letting warm in and cold out giving same results.
Mar 02, 2012 | GE Profile PFSS6PKX Bottom Freezer French...
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
My fridge keeps leaking water and the inside becomes warm for a few days, everything melts in the freezer. Then it works again. Please help.
HI,REMOVE EVAPORATOR COVER IN THE FREEZER COMPARTMENT AND CHECK THE DRAIN,IF ICE MAKER IS INSTALLED CHECK FOR ICE MAKER LEAKS,
Jul 05, 2011 | Kenmore Top Freezer Refrigerator
Getting water on floor water line is not leaking
First check the inside of the freezer at the bottom and see if you have a block of ice on the freezer floor.... if you do then your defrost drain is cloged.... use warm water to dethaw
if you do not see the drain hole then it is behing the back wall where you see the vent .... in side the freezer. use some warm water.... This will take a while and will be wet ... get a couple of BIG towls and keep the warm water comming untill the water drains....
Not : once it drains stop pouring water in it .... It only hold 1 or 2 cups in the pan under the machine.
if this is not your problem then you most likely have a water line leaking or a water valve leaking under the machine.
Oct 06, 2010 | Frigidaire Refrigerators
Water is leaking out from the bottom of the freezer
Below the freezer coil is a drain trough. Sounds like it is frozen. Use a hair drier to melt it and poor baking soda with warm water down it.
Jun 02, 2010 | GE Profile PSS26NGS Side by Side...
The refrigrator is warm and fills up with water.Freezer to cold.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jan 02, 2009 | Whirlpool ARC4030 Stainless Steel Top...
Leak
Is there ice build up under the bottom basket in the freezer??
sounds like the defrost drain is frozen up. especially since your cleaning up once or twice a day. simply defrost the drain and flush the drain line with warm water. you will likely have to remove the freezer cover inside the freezer compartment to do this.
if there is no ice build up under the baskets then its likely there is a leak in the water line for your water dispenser line that runs in the door. if thats teh case you will most likely need a service company to fix it for you..
Dec 19, 2007 | Admiral 26 cu. ft. Side-By-Side...
Same problem no solution not sure but need help bad fridge is getting warm
Not cooling at all? or other symtoms that can help us get you going. Can you make sure the refrigerator is listed as Kenmore
Here are some examples of model numbers for this appliance: 106.8782070, 596.58692890, 119.909851, 119.3101279, 198.887482, 253.835123
•  Inside the refrigerator or freezer, on the upper left or right side wall
    •  Behind the lower crisper drawer
    •  Behind the lower toe kick-plate
    •  On the face frame of the refrigerator body
Can you help locate these numbers so I can assist you with the drawing of that door?  TKS,Sea Breeze
Oct 24, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool ET8MHK Top Freezer Refrigerator Logo
191 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
