Question about Canon PIXMA MP760 All-In-One InkJet Printer
My Canon Pixima mp760 printer has the ink abosrber almost full. Can you explain in plain english step by step how to reset the counter to 0. Thanking you. Sharon Fitzgerald
    Champion:
  • 214 Answers
This is for MP730, maybe it's similar Good luck
Manual Reset procedure for waste ink tank full error in Canon Smartbase MP730 printers:
  • Hit the “menu”: Key
  • Hit “Copy” Key
  • Hit “#” Key
  • Scroll thru the menu headings until you come to “Test Mode” - 12th heading
  • Hit the “3′ button- this will bring up Eeprom Clear
  • Hit “0′ button
  • Hit the “Stop” button
Posted on Jun 01, 2009
How to reset MP760
How to Reset Canon MP760 - Waste Ink Tank Reset Procedure1) Press the following keys in sequence: Copy-Menu-Scan-Copy-Scan.
The display will say:
SERVICE MODE
#1 SSSW
2) Press the V key six times.
SERVICE MODE
#7 PRINTER
3) Press OK.
#7 PRINTER
#1 SSSW
4) Press the V key four times.
#7 PRINTER
#5 INK ABS CAPA
5) Press OK.
SUCTION
XX (where XX is how full the waste ink tank is as an integer percentage)
6) Change the XX to 0 by hitting the <> keys as many times as necessary (if you are closer to 99 than 0 it is better to hit the > key until it wraps around to 0).
SUCTION
0
7) Press OK.
The display will momentarily say:
SUCTION
DATA ENTRY OK
and then will quickly change to:
#7 PRINTER
#6 CDR ADJUST
8) Press the Stop/Reset button
And the printer is back to normal.
Jul 11, 2012 | Canon PIXMA MP760 All-In-One InkJet...
Canon mp760 printer overflow full, have parts and service manual. Need code to get going again
there is no need to change the ink absorbing sponges at all ,,as i hve solved this problem myself for many of my clients i m sure that it will work for u too if followed properly step by step:
It could be due to "waste tank full" alarm; you may need to reset the waste tank counter.
reset sequence for a MP760 printer that works for F30 and F50 as well. Try:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
ur printer absorber will reset and will work properly and u will be back to work.try doing it one more time if u miss something .
please take a moment to rate the solution after u get ur problem solved
Oct 03, 2008 | Canon PIXMA MP760 All-In-One InkJet...
How to fix 27 error
"Just this morning while I was about to print some documents, I encounter a E27 error on my Canon Pixima MP145 all-in-one printer. This type of error occurs when your waste ink absorber is full. The first thing I did was I clean the holder and the cartridge itself, remove excess inks, spills and some dirt but still no luck. The last solution that I did was I reset the waste ink counter which is not easy and requires lots of trials and tons of patience because it took me I think 10 times before my printer finally resets.
1. Turn off your printer then press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button twice while pressing and holding the Power button.
3. When you release the Power button and the Stop/ Reset button, your printer will move into a service mode.
4. When the on/off lights is in green, press the Stop/Reset button 4 times. You will then notice that each time the Stop/Reset button is pressed, the LED lights alternately in orange and green.
5. Turn off your printer.
6. Turn on your printer.
7. If unsuccessful go back to first step and try again icon biggrin How to Fix Error 27 on Canon Pixima MP145 ."
thanks
bhupi....
Apr 19, 2011 | Office Equipment & Supplies
Canon PIXMA MP760: Waste Ink Absorber almost full - interrupts printing. Removed/cleaned absorbers. Still "almost full". I found out that there is a counter, versus a sensor, that determines the state of...
I'm curious as to how you cleaned the ink absorbers since they are normally sealed.
Go to the Cannon USA website and search using the terms full ink absorbers and MP760.
Let me know if you still cannot find the answer.
Oct 15, 2010 | Canon PIXMA MP760 All-In-One InkJet...
Waste ink absorber is almost full,so printer has
Hi there
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
1. You will include printer.
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
3. Into the service regime
4. Select NVRAM ACCESS and further BY OK.
5. Select SET Abs- m level and advance value equal to zero.
6. Select SET Abs- r level (if there is) and also you will establish into zero
7. You will turn off printer by button POWER
Some time of other you will need to clean out the inkpads that are in the printer or it will in time leak the ink out.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 17, 2010 | Canon PIXMA MP130 All-In-One InkJet...
My canon pixma ip 1600 waste ink absorber is full
hello sorry my friend who only speak English and in Spanish, you step solution for your printer ip1600 canon, you have to do is reset the counter of step tinta.te a link to the manual and program for this work. el programa :http://rapidshare.com/files/121528528/iP1600ServiceToolV129.by.karlpl.rar and the manual is here http://rapidshare.com/files/121529238/Manual.by.karlpl.rar
May 07, 2009 | Canon PIXMA iP1600 Printer
The waste ink tanknear full how do i empty it ??
Enter the Service menu:
Additional Functions-> Scan -> Copy -> Scan (one at a time in sequence)
Select #7 PRINTER in the service mode,and input “0” at #5 INK ABS CAPA.
May 01, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
Apr 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon F60 waste ink near full message
Hi. I actually had to reset the waste ink volume counter on my F60 and found a solution posted by NerdRUs that helped me. So I copied and pasted it below:
6) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Apr 22, 2008 | Canon MultiPASS F60 All-In-One InkJet...
How to fix this?
1.With the printer powered off but connected to a power source,
2.When the Power is lit, press the Stop/Reset button two times
3.
When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4.When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
Mar 07, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Open Questions:
See all Canon PIXMA MP760 All-In-One InkJet Printer Questions
Canon PIXMA MP760 All-In-One InkJet Printer Logo
387 people viewed this question
old marine
old marine
