Question about LG 42PG20 42 in. Plasma HDTV
Vertical Pin strip lines across the screen of a 42pg20 plasma tv
I have vertical pin strips that come and go, most of the the time they only last a day or two.The lines are perfectly spaced out about 2 inches apart roughly 30 lines.i have a surge protector on the tv and have all the extras on a surge protector to(ps3, wii and cable box). The service guy came out to look at it but if the line are not on the screen he cant really do much. Please if anyone has a idea of what might be causing this please help me out I'm out of ideas!!!!!!
  • 31 Answers
SOURCE: 50" LG Plasma - Thin red vertical line in middle of screen
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
Posted on Mar 10, 2008
  • 6 Answers
SOURCE: Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Posted on Mar 23, 2008
SOURCE: plasma tv red strip
i have a vizio 42 inch plasma with black line across screen in viewing mode or blue screen. The tv is only 8 month old
Posted on Feb 06, 2009
  • 22 Answers
SOURCE: LG RT-42PX10
everyone's lucky day!  follow this link closely!  it will work!  it worked for me on my gateway, which has LG boards.  trust me.
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Posted on Apr 28, 2009
SOURCE: black vertical strip on Hitachi plasma
rcrumpsi
Did this fix your issue? I have the same issue with this model. If so, was it very expensive?
Posted on Nov 15, 2009
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Where is horizontal scan out put section?
Hi Majid
Just contact any service technician to repair your TV. It will be best for you.
Gopakumar Gopalan Google
Feb 01, 2015 | Televison & Video
Panasonic TH-42PX70B plasma tv vertical very this coloured lines in band about thrd of way across screen from right hand edge what is thesolutionto fix this problem
Sounds like COF (Chip On Film) strip fault. Check this link for more details. There is illustrations [screenshots] and reasons to plasma displays. Check it out, and compare them with your TVs fault. Pull up older posts there.
Mar 07, 2013 | Televison & Video
Vertical colouered lines on the right side of the screen...
If it looks like a pin or magic marker drawn straight down the screen, it most likely is a de-laminated flex cable to the glass, if it is the panel needs replaced.
Sep 01, 2009 | LG 42PG20 42 in. Plasma HDTV
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
20" orion tv
Hello mel2003,
This problem is caused by the loss of vertical deflection. Either the vertical output section of your TV or the vertical coupling capacitor has completely failed. In any event you will have to have a TV technician fix this set, BTW I hope you have not been playing the TV with the line on the screen this will burn the TV screen.
I hope this helps
Thank you,
Shuttle83
Jun 16, 2008 | Orion1934 19" TV
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical black line on screen
Your set has either a bad driver board or more likely a bad plasma panel.
Oct 18, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Picture problems
If the line goes across the screen you have a loose solder joint on the vertical output IC. I've seen this happen many times in Zeniths and a lot of other sets. If the IC is not loose then there is a loose solder joint somewhere else in the vertical circuit. These IC's are 10 - 13 pin chips that operate the vertical deflection on your set. I feel like a drop of solder in the right place will fix it! Stargazer
Apr 10, 2007 | Zenith C27A24T 27" TV
LG 42PG20 42 in. Plasma HDTV Logo
113 people viewed this question
Computer Repairing
Computer Repairing
