Question about Veo Advanced Connect Webcam
My computer recognize the cam but nothing comes up on my screen?
When I plug in my cam the new device pop up comes up recognizing the cam but nothing comes up on my screen. do I need to be in a certain program to use the cam or is it that i do not have the driver and if its the driver where can I get one?
  • 256 Answers
When the new device pops up, it should tell you if it installed the device and if the device is working. If it did, the it should be listed in Windows Explorer similar to a disk drive. If it is there and you click on it the the right side of Windows Explorer should display the camera view.
If there is no camera in Windows Explorer, then go to control panel and see if you can find it there. Depending on your Windows, look under Imaging Devices, Devices and Printers Camera & Scanners.... If there is no listing for it, the driver did not install. Locate the driver for the camera and install it.
Posted on Jun 01, 2009
I have a Dell 530 S Dell Inspiron. Its Webcam has stopped working. Any solutions
The very first step is of course to check your web cam connection. Most web cams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in web cams this steps does of course not apply. Many new laptops have a build-in web cam. Also try connecting your web cam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
Other devices in Windows XP device manager
If the device is not recognized in Windows XP, Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer.
After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.If your problem is not fixed then you have to buy a new one.
Hope the above information will be helpful to you.
Thanks.
Oct 08, 2010 | Dell Inspiron 530 Desktop Computer
E250R not recognized by computer after downloading itunes
maybe your USB cable is not perfectly functioning try to use other cable, ant then turn on your mp3 player
Jun 30, 2009 | SanDisk Sansa e250 MP3 Player
USB DEvice not recognized
Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
Mar 06, 2009 | Canon PowerShot SD790 IS Digital Camera
Wireless mouse won't work
Perhaps try the device manager.(click) My Computer>Manage>Device Manager.
Feb 22, 2009 | Sony Computers & Internet
Phillips go gear 8gb
Reset the player by inserting a paerlcip into the reset hole. If that fails, go to Philips' website and upgrade the firmware on your player to solve the freezing issue permanently. Actually, don't go to Philips website - run the Philips Device Manager and select Update. If the device manager won't recognize the player, unplug the GoGear, hold in either the shuffle button or volume + and reconnect it to the computer until a Found New Hardware Wizard window pops up.
-Tha Mp3 Doctor
Dec 29, 2008 | Philips GoGear SA5285/37 Digital Media...
My computer no longer recognizes my JVC GR-D70U mini DV cam when I plug it into a usb port.
Hi, I am not sure. But I believe the camcorder has to be on when you connect to the computer. and I assume you use firewire for this particular camcorder.
I too once had this problem when I used Windows Vista. If you too use Vista, try it with Windows XP.
cheers,
Sep 19, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
When I plug in the webcam, it says USB DEVICE NOT RECOGNIZED
These camera seem to be delicate. Call Microsoft support number that is on the documentation and they will send you another one. I did this and the replacement VX-3000 works perfectly.
Jun 24, 2008 | Microsoft LifeCam VX-3000 Web Camera
My sandisk c240 charges when plugged in but fails to be recognized on the computer
There is quite possibly a problem with the USB cable or the USB port on the computer, but try this shortcut force to force the computer to recognize the Mp3 player: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 23, 2008 | SanDisk Sansa c240 MP3 Player
No response, no turn-on, dead player! help!
Same thing just happened to my M260, did you ever get an answer? Thanks, Jeff. Problem: No response, no turn-on, dead player! help!by mtx410 on Aug 28, 2006 I was loading files, when the transfer locked up, and the computer threw an error. i couldn't do anything but unplug the player! After I did this, i tried plugging it back in, and half of the world "initializing" popped up on the screen, the first half was missing! it did not do anything more. so i unplugged it again. Now when I plug it in, nothing happens. The computer recognizes that new hardware is plugged in, but cannot recognize what it is. Nothing comes on the mp3 player's screen. It will not power up when i hit the power button. It has no response, it acts like there is no battery in it. I have taken the battery out, and put it back in. Nothing happens when any of the buttons are pressed, or when it is plugged into the computer. Is there anything I can do to get this thing working again! It is the M260 if that matters.
Aug 28, 2006 | SanDisk Sansa m200 (2 GB) MP3 Player
Veo Advanced Connect Webcam Logo
Top Veo Computers & Internet Experts
micky dee
Lyle Siemens
Lyle Siemens
Radames Pagan
Radames Pagan
Are you a Veo Computer and Internet Expert? Answer questions, earn points and help others
