Question about Iomega (33215) 250 GB Hard Drive
Weird clicking sounds
My iomega hard drive just stopped working. The power light is on and its making some weird noise but it will not connect to my desktop or laptop computer I have a similar problem, the external hard drive is not being recognised, i've tried restarting, plugging in and out, hitting, etc. still no luck. PLEASE HELP!!!
    President:
  • 2,923 Answers
Clicking sound on an external hard drive is an indication that it's quiting to work. You mentioned that it's just stopped working, you may need to check the Disk Management of your computer to see if you could still reformat it. To do this, please follow the steps below:
FOR WINDOWS XP AND VISTA:
1. Make sure that the HD is properly connected to the computer.
2. Right-click 'My Computer' or 'Computer' folder and then go to "Manage".
3. Locate and click Disk Management.
4. Then, take note of the drive letters that will appear on the screen.
5. While the Disk Management window is opened, unplug the HD and check which drive letter will disappear.
6. If a drive letter disappears, then that is your external 250GB HD. You may reformat it to make it work again.
NOTE: Reformatting the HD will erase all the files saved in it. You may want to bring your HD in any data recovery center to retrieve the important files. If the HD didn't show up under your Disk Management, then there's nothing that we could do but to bring your HD in to the Data Recovery to save the files.
FOR MACINTOSH OSX:
1. Connect your HD to the computer.
2. Click 'Go' (located near the Apple icon, Finder, File, Edit and View).
3. Select Utilities and then click the Disk Utility Icon.
4. Take note the drive letters and then unplug the HD.
If a drive letter disappears, that's your HD. If nothing disappears, then the computer no longer detecting the HD.
Posted on Jun 01, 2009
Weird beeping noises
Need to know what make and model of laptop you have. It could be the CD drive's internal hardware, or the hard drive beginning to fail, or even a failing fan. You may be able to get MSI to repair it for free if you call them (If it's a warranty issue).
You should make a back up of anything important on your laptop if it's about to fail...
Jan 14, 2014 | MSI Computers & Internet
Iomega lphd160c
Sounds like the drive is broken/damaged
You can try removing the drive from is case and connecting it direct to the computer. There are youtube clips to help you do this.
Dec 30, 2013 | Computers & Internet
My iomega 1tb hard drive stopped working and is not being recognized, how do i get my data ?
You must do quick format, no full format, then, after it , you can us ,,Recuva,, or ,,Easy undelate ,., programms, for recover your files,
or it http://www.diskinternals.com/fat-recovery/, its too very good programm.
Apr 24, 2012 | Iomega Computers & Internet
My 500gb wd "my book" is making weird noises and wont show up
The whirring noise is the heads trying to read hard drive and then the weird rubbing screech sound and not showing up in your pc. sounds like the drive is dead.
Jul 14, 2010 | Western Digital My Book Essential 500GB...
Odd clicking noise...
That clicking sounds if ever loud enough is one annoying symptoms of failed disc. When it accidentally drop the reader may come off the disc. It sad to say but you may consider to change your hard disc.
Jun 12, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Iomega 250 GB external stopped working
This is really not a solution, but you should all try to connect your iomega to a imac, and use the Disk Utility (in Utilities folder), if you have any luck the hard drive will be recognized and you will be able to format it
Dec 18, 2008 | Iomega (33215) 250 GB Hard Drive
Weird noises, not recognized by laptop
This is a common problem with hard drives. Most hard drives (whether external or internal) that produces a "weird clicking noises" indicates a mechanical problem. Often this is the head arm trying to move from its position but failing to do so. What you are hearing as "weird clicking noises" are when it slaps back to its park position or when trying to move into correct position.
Should this be the case, am afraid that the HD is a goner. The normal course of action is to replace. If the data inside are mission critical, your only course of action is to avail of those data recovery by firm specializing in such but they are rather expensive.
Trying to use "data recovery software" might prove to be futile since as earlier stated, the problem is mechanical in nature.
You can of course still give it a try.
Should you feel adventurous, would be willing to experiment and gamble, pls post back as I may have not a permanent solution but a "down & dirty" trick of making it run long enough hopefully to get some of your data back. Again, this is a "hit or miss" and should only be considered if all else fails and you really want to get your files back.
Hope this be of some help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Feb 04, 2008 | LaCie d2 Extreme with Triple Interface...
Weird Noise
Yes.If your HDD is making any real loud noises,the drive is U/S.
Yes,retrieving your files from this drive is possible but ultimately expensive.Sorry,but once HDD is U/S,thats it.
Feb 03, 2008 | Computers & Internet
Iomega CD-RW won't read cds and makes a weird noise.
sounds like something jammed.
https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/cust_alp.php?prod_lvl1=5&prod_lvl2=668&p_prods=5,668&cat_lvl1=50&p_cats=50&p_pv=2.668&p_cv=1.50&p_sid=1NmDOTSi
Dec 10, 2007 | Iomega (32885) CD-RW Burner
Iomega (33215) 250 GB Hard Drive Logo
854 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
