Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Electrical wiring for kohler engine
I'm looking for a diagram for a 14hp kohler engine model K321A, spec no. 60258d (garden tractor). Did some work on it and i really need the proper electrical hook ups to the generator and voltage regulator. Generator is heating up and i suspect the wiring is not correct. Is there any possible way to get this diagram? I am looking for a manual or diagram that has the electrical system and also an owner's manual for a Kohler 14 HP K - 321 AQS Spec. No. 60244-D. The make is a Ford 145 Lawn and Garden Tractor. Thanks so much!
I have a Ford LGT with a 14 hp Kohler K321AS engine. Go to Kohler.com and download the service manual for the K321 engine. The manual covers all of the K type engines and gives diagrams and details of all the different types of ignition and electrical systems. It is free. JS
Posted on Jun 07, 2009
I seen a complete papper repair manual on ebay for the kohler321 i belive it around $9.95 if you wish to purchise a manual that is the seller is @ http://stores.ebay.com/Usherwoods?_trksid=p4340.l2563
Posted on Dec 02, 2011
14HP Kohler engine in JD314 garden tractor has no spark - new coil, condenser and battery - cranks over strong but will not spark
Your problem is electrical. .. there's gotta be a short ... check if there is an emergency shut off switch, under the seat, disconnect that.. the unit is sending a signal to stop the coil from sparking, I'm certain that's your problem!
Oct 05, 2015 | Garden
Show me a wiring diagram for a 13ac762f755,i put a 14hp command,kolher on it tring to wire it up.
Mower side connections At engine connector.
Yellow = Magneto
Red = Alternator DC
Blue = Alternator AC = Lights
Red/Black = Afterfire Solenoid
If the Kohler only has DC output jumper Red and Blue for lighting.
Apr 13, 2015 | Garden
What is the head bolt torque specs for a Kohler Pro 25HP V-Twin engine?
Go here and look up your engine model
Owners Service Manuals
Here is a Manual for the Kohler Command Pro CV26
http://www.kohlerengines.com/onlinecatalog/pdf/24_690_02_EN.pdf
The picture shows the torques of the Kohler Command Pro
Aug 19, 2014 | Craftsman Garden
How to reconnect kohler goveners
Without the numbers from the engine I can not get you the exact breakdown you need, this might help.
https://images.search.yahoo.com/search/images;_ylt=A0LEVy51DUpT0jUAMvlXNyoA;_ylu=X3oDMTB0Yjkwb3VoBHNlYwNzYwRjb2xvA2JmMQR2dGlkA1ZJUDM3MF8x?_adv_prop=image&fr=yfp-t-301-1-s&va=18+hp+kohler+engine+governor+diagram
If you give me the numbers including the spec number I will get you the breakdown you need.. Best of luck to you, please let me know if i can help..
Apr 12, 2014 | Garden
Changing from kohler 12.5 to kohler 14hp
Go to http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10051 Type in your model no. and serial no on mower. Locate correct manual, you will then have to trace wires on both motors and make them correspond.
Mar 07, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Perhaps you would enjoy the entire service manual. Here it is: http://www.asberry.net/files/TP-2379.pdf
Feb 26, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
3,644 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
Craig Butler
Craig Butler
John Trevino
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
