Question about Dishwashers
Dishwasher was opened to add dish and would not start back
My wife had just started the dishwasher and after it started running for a couple of minutes, she opened the door to add another dish.
When she closed the door it would not start back.
The control panel is not lighting up.
I checked the breaker, and after finding it was ok, I checked the power chord with a tester. It showed there was power to the dishwasher.
I opened and closed the door several times to make sure the door was closing all the way and was locking and everthing seemed to be fine, except the dishwasher acts like there is no power.
I was wondering if there is a reset button or should I check something else?
Thank you in advance for you help.
Wes
  • 211 Answers
What model dishwasher is this? Most dishwashers have a safety switch that halts the wash cycle if the door or latch is opened. I would check this first since the problem originated while opening the door.
Posted on Jun 04, 2009
  • 46 Answers
Give it a few minutes it may have a built in delay when cycle is interuptede
Posted on Jun 01, 2009
We have a Kenmore Elite 630.16304401 dishwasher, lately we are getting small black greasy spots on the plastic dishes, also same spots on the plastic parts in the sump where you clean the filter? We h
A couple of thoughts:
1) It could be a gasket somewhere starting to break down. Check your door seal.
2) Food particles could have gotten caught somewhere in the drain hose, or something, and then turned black with mold and bacteria, then when you wash, they get siphoned back into the dishwasher if the flap which composes the anti-siphon check valve on the drain hose is starting to stick open.
Try putting a cup of bleach in the top rack and run a complete cycle with no other dishes in it. Then, load up some plastic dishes and wash them as normal. See if that helps. If it does, replace your check valve.
Also, insure that your drain hose is looped up above the bottom of your sink to prevent debris from your garbage disposal backing up into your dishwasher.
Good luck and keep us posted!
Oct 22, 2014 | Kenmore Dishwashers
Stuck on a cycle
In some cases it happens. Such circumstances, switch of the machine wait, Re start.
Apr 11, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
I have gritty debris on the dishes, it appears the small bits left on the dishes before loading get broken down and rinsed onto them as grit again! The dishes are not spotless going in but they are scraped...
1. it can be water backing upfrom maybe a garbage disposer like a clog ,or fill jet dry compartment completely.add nad fill then open and close the door 3 times then you will be able to add more what you are doing is taking out the air in the dispenser.once it is filled completely last thing is to make sure the water ghoing into machine is hot,then start the machine for best results. let me know if i have been of some help
Feb 24, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Lots of stuff left on dishes and glasses real filmy
run unit through a clean cycle. turn on hot water at sink til it gets hot then shut off . then tuen ion dishwasher when it starts washing open door and add 2 cups of white distilled vinegar and let it go through a cycle ( no dishes) when done. turn on hot water at sink before you use dish. also fill both soap cups and use rinse aid or jet dry. you should see better improvements. hope this helps..
Sep 17, 2009 | Kenmore Dishwashers
Dishes have cloudy film on them
Try this. I want you to run your dishwasher empty, on the hottest water setting. Let it fill and just before it starts the wash cycle put in three cups of white vinegar. I expect your jets are clogged and the vinegar should hopefully open the jets back up. You don't need to add soap during this cleaning process. Works just like when you clean your coffee maker.
Apr 23, 2009 | GE Dishwashers
LG dishwasher model #LDF6810ST doesn't DRY DISHES.
ok ...first the average dishwasher will only heat the water 1 degree per mintue,,,now if your starting out with very cold water the dishes will never get clean check your water temp,,at start up..if you have 90 to a 100 degrees thats ok..that means we have problem in heater circuit...also turn up your jet dry level...keep me posted onthejob,,incase we have to look at heater circuit
Dec 31, 2008 | LG LDF6810ST Stainless Steel Built-in...
Not starting
Getting Started
1. Load dishwasher (See Preparing and Loading Dishes).
2. Add detergent (See Dishwasher Dispenser & Detergents).
3. Add rinse aid, if needed (See Rinse Aid).
4. Close door to latch.
5. Select desired CYCLE (See Cycle Chart).
6. Select desired OPTIONS (See Energy Options). The indicator light above the pad will glow when selected.
7. Run hot water faucet nearest dishwasher until water is hot. Turn water off.
8. To start, press START/CANCEL pad.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Kinston/154575401.pdf
Jul 14, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Viking Dishwasher leaves a film on the dishes
Hi! I found a great product at www.dishwasherfilter.com that will take care of this problem for you and your wife. It mounts under the sink and works great!
Use promo code DF5150 when ordering for an additional discount!
Dec 16, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Cranky dishwasher
You want to make sure that the dishwasher is level and secure first of all. Then I would look into the door latch assy. Sounds to me that you are not making all the latch switches when closing normally. When you are slamming it, you are making the switches. The heating element runs through the neutral side of switches, therefor if the switch is broken or the latch is not making, no heating of the water. This results in a default or very long wash time. Check this out first....Catriver..post back.
Oct 15, 2006 | KitchenAid KUDS24SE Built-in Dishwasher
Dishwashers Logo
150 people viewed this question
Top Dishwashers Experts
Owen Barnes
