Question about Microwave Ovens
No heat. light ok, noise hasn't changed. I heard a pop
No heat, light ok, turn table ok, noise hasn't changed. Runs ok but there isn't any heat. Model JVM1430
    President:
  • 1,489 Answers
It's most likely the relay for the magnetron malfunctioning. It'll need professional service.
Posted on Jun 01, 2009
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Oct 16, 2012 | Sharp R-1510 Microwave Oven
Less than 5 years old - Microwave Panel lights up, turntable turns, fan works - everything works except it doesn't heat food. Heard a pop, and now it runs louder than before but doesn't heat. Any ideas?
That pop was the magnetron frying. This is a repairable problem, but feirly expensive, around $300 if you have it done by a professional.
Please rate my response if it was helpful to you.
Thanks, Repairman45.
Dec 02, 2010 | Frigidaire PLMV169DC Microwave Oven
Yesterday, I went to use the microwave and as I pushed start, I heard a loud pop and saw sparks behind the vent cover. The microwave light and turn table work fine, but it does not heat. Is it repairable?
sounds like your magnetron went out . check how old it is, sometimes the manufacture gives a 5-10 yr warrenty on part if no warranty on unit then it may not be worth fixing depending on how much u spent on it. part roughly 89.99-139.99 labor 85-165.00 depending on who u use and were u live. hope this helps . thanx..
Oct 07, 2009 | Whirlpool Microwave Ovens
Microwave seems to work but does not heat food
OK, you may have a damaged thermostat or, the Magnetron may be damaged as well. you can test each device with a meter(ohm,volt).
replace any parts that dose not register.
Jun 03, 2009 | Panasonic Microwave Ovens
Spacemaker XL1400 GE Microwave
my xl1400 spacemaker ,it just won't heat, everything else works
ok, can you all advise me what to do, what could be causing it to not heat.
wendell
Dec 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker xl1800 and Pop tarts bad mix
it sound to me as if the high voltage diode is shorted. It could be inside the capacitor or out board the cap. The capactor could also be short but this is a rarity. Diodes are a cheep item . repace it and if it don't work its probably the magnatro. good luck.
May 13, 2008 | Microwave Ovens
more than likely the fuse has blown onthe magnatron it is the button looking thing on the magnatron with two wires. there are 2 of these one is on the magnatron the other is above the heat box test these for open. if open replace. if good then replace the magnatron.
May 02, 2008 | Microwave Ovens
Emerson Model MW8627W does not heat after changing fuse!
check the magnitron and capacitors one of this is bad
Sep 18, 2007 | Emerson MW8627W Microwave Oven
Microwave Ovens Logo
176 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
