Iwant to know how to wire the ignition coil to the distributor
SOURCE: diagram for replacing distributor, cap, rotor...
Replace the coil. It is shorted out. I have changed quite a few coils for the exact same symptom.
The graciousness of a FixYa rating for my assistance would be appreciated.
Thanks for choosing FixYa for assistance.
SOURCE: engine replacement - distributor vs. coil pack - 97 Tacoma 2.7L
ok, try to put all accesories from your old engine to used engine, toyota dont make conversion kit, and the distribuitor is not compatible with your wires
SOURCE: 1984 toyota pickup 22r motor. No fire to distributor
At the cost of the igniter i recommend checking your pickup coil.( The 2 wire sensor in side of your distributor. The The igniter will not allow the coil to fire with out reference form the pickup coil. Coil has primary and secondary resistances. when the primary coil powers up and then pulses off, this cause a high voltage due to magnetic degeneration. Check the coils primary and secondary resitances along with the air gap in the pickup coil, and also check the resitances on the pickup coil. If i am right your igniter will be okay.Get a good manual for you truck, It will save you money down the road.
Toyota does not have at test proseger for the ingiter.
Also check the wires in between the pickup coil and the igniter.
I hope this helped.
SOURCE: 1993 toyota corolla, problem no spark to spark
Check the ignition relay and all the main relays on the battery.
