Question about Whirlpool RBD305PD Electric Double Oven
Whirlpool electric double oven #RBD305PDQ14 control panel blank
We have a Whilpool electric double oven model # RBD305PD. Out of the blue, it started to beep and there is no digital display on the control panel. The light function works and it sounds like it is firing up when you press the Bake button. Turned power off for ten minutes and when power restored the same problem occured. Same problem. Tech came and fixed control panel but said that this is defect in model and not to use self-clean option or it would happen again. Didn't self-clean but it happened again anyway. What a disappointment - NOT a cheap appliance. No help from Whirlpool.
  • erica graber May 11, 2010
    so did they replace the controller or the touch panel? hopefully they replaced your EOC if there was no display. EOC means electronic oven controller. unless what happened to you was 2 seperate issues for example when you did a self clean usually this blows your TCO (thermal cutoff) but this does not kill your display this just kills your heat bake and broil. Is this what happened?
    Top Expert:
  • Whirlpool Master
  • 80,607 Answers
I suspect a poor connection at the wiring to the EOC is the cause of the failures.
Posted on Apr 21, 2017
2 Suggested Answers
SOURCE: Whirlpool electric double oven #RBD305PDQ14 control panel blank
The control panel part on my Whirlpool double oven (part #8302319) went blank six months back. Replaced it. Asked if there was a warranty on the part, was told no there was not. Yesterday, the six month old control panel went blank. Disappointed that Whirlpool manufactures such garbage.
Posted on Feb 01, 2010
How to clear F2 E1 error on a whirlpool double oven
E1 F2 is most often due to a failed keypad. Depending on your exact model the original part may be no-longer-available. However, there are replacement membrane switches available here:
Introducing the Ledgestone Technologies Touchpad
Models: RBD305PDB10 RBD305PDB11 RBD305PDB12 RBD305PDB13 RBD305PDB14 RBD305PDB15 RBD305PDB7 RBD305PDB8 RBD305PDB9 RBD305PDQ10 RBD305PDQ11 RBD305PDQ12 RBD305PDQ13 RBD305PDQ14 RBD305PDQ15 RBD305PDQ7 RBD305PDQ8 RBD305PDQ9 RBD305PDS12 RBD305PDS14 RBD305PDS15 RBD305PDT11 RBD305PDT12 RBD305PDT13 RBD305PDT14 RBD305PDT15 RBD305PDB1 RBD305PDB2 RBD305PDB3 RBD305PDB4 RBD305PDB6 RBD305PDQ1 RBD305PDQ2 RBD305PDQ3 RBD305PDQ4
Jan 08, 2014 | Whirlpool RBD305PD Electric Double Oven
Rbd275pdb12
Control Panel has likely failed (circuit board). You can try removing the power wire from the back of the panel and then replug it back in to see if it resets the board, but Im sorry to say your likely going to have to remove and replace the control panel.
Dec 02, 2013 | Whirlpool RBD305PD Electric Double Oven
I have a Whirlpool RBD305PDQ8. The display is blank, but will beep when pushing the buttons. If I attempt to start the oven, it will not turn the oven on and will have a series of beeps. Do I need to...
Up there in the controls is a bullet fuse like this:
Designed to kill power to the controls if it gets too hot in there so the controls won't be harmed. That could be it but I don't know if it would beep if the fuse is blown, that could be a bad control. Use this manual to help you diagnose:
Whirlpool double oven repair manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 26, 2011 | Whirlpool RBD305PD Electric Double Oven
Key board will not light up...Nothing....Oven light will come on......TTT
Whirlpool RBD305DQ15 Electric double wall oven, the control panel does not light up so you can't tell what you are doing. Do I need to replace the whole board or is there a fuse to replace?
Oct 05, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool Accubake System Mod.# RBD275PB10 front panel blank
GBD RBD Whirlpool Oven Problems Causes and Solutions
Hello Edward!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
May 13, 2017 | Whirlpool RBD305PD Electric Double Oven
Whirlpool RBD305PD has error F2E6 error on control panel
When this code appears and display is going blank too, it is always the control board. The only option is to buy a new one or get it repaired. It can be fixed quickly and reliably. www.fixyourboard.com
Apr 02, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool Double Oven RBD305 Display doesn't show, oven wont work
Most definitely a bad control board and/or soldered components. (The part about cutting power to the oven was a dead giveaway)
There are low and high temperature solders, but usually solder melts at 370° F. If the oven is improperly insulated or ventilated you will have continued heat stress to the control board.
Mar 31, 2017 | Whirlpool RBD305PD Electric Double Oven
Control panel for oven functions has gone blank with occasional beeping sounds
The control panel may have a power issue. Replacing the board fixed my problem. It looks like 4 resistors and a ZD1 diode heat up and fail. The U1 chip could also be a problem. If you replace the controller it will cost around $225. Be careful of the key pad ribbon cable. They break easily. Another $186. Good luck.
Oct 16, 2008 | Whirlpool RBD305PD Electric Double Oven
Whirlpool RBD305PD Electric Double Oven Logo
481 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
