Question about Zebra TLP 2844-Z Thermal Label Printer
Printer issue in printing
Am using zebra TLP 2844, my paper skips when i press red button to green,.... can u help me to reset to Factory setting...
Re: Printer issue in printing
I was told by Zebra tech to attach it with a parallel cable, click on Start, Run, type in CMD and press enter. This takes you to a DOS prompt. type in the following:
cd\ (enter)
ECHO O>LPT1 (enter)
ECHO ^default (enter)
ECHO ^default>LPT1 (enter)
Make sure you follow the capitalization exactly.
Posted on Dec 04, 2007
0 characters
3 Points
Zebra TLP 2844 printing landscape instead of portrait.
To change from "page mode" (protrait) to "line mode" (landscape) you need to complete the following steps.
1. turn the power off
2. hold the feed button down
3. turn power on, the feed button should blink, release the button.
4. when the feed button blinks green, press and hold until it turns red or amber. release the button.
5. turn the power off.
6. hold down the feed button and turn power on, the button should blink and release. it will now print a calibration page. 4 blanks followerd by 2 text pages, the last saying "Now in DUMP" press feed to exit. on the first print, the 4th line down will say either page mode or line mode.
Nov 04, 2009 | Zebra TLP 2844 Label Printer
TLP 2844 GAP sensor problem (I guess)
I had the same problem. I found out later there was a small piece of label sticking against the sensor, thus blocking the sensor from sensing the end of the label. As soon as I removed the label (open the cover, it is on the top part) it immediately started to work as usual. Hope this helps.
Apr 22, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Zebra TLP 2844 tis not detedting the paper.
It turns out that I kept overlooking one printer setting. It was set for thermal printing rather than direct.
Mar 19, 2009 | Zebra LP 2844 Thermal Printer
Hi, My printer model is TLP 2844.i m facing the problem in printing. The printer is hang after one or two lines printing and red LED are ON and I press Green button repeat same as before. Please solve my...
Solid red light. This indicates the printer is in an error state and will not print until the error is cleared. Check to make sure the printer is not out of labels or out of ribbon if it is a TLP model.
A solid red light will occur if
  • the printer is out of labels
  • the printer is out of ribbon ( TLP models only )
  • the printhead is open, not latched down all the way. Press down on the top cover of the printer to see if the error light clears and goes to green.
  • the ribbon spool is slipping on the ribbon spool holder on TLP models:
These 2 links will help you troubleshoot the problem:
Click on this link. Or copy and paste it into your browser.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
Mar 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra Printer TLP 2844-Z - Will not print from application - prints SM 10 53 4D
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Oct 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Error triying adjust labels on zebra tlp 2844
Try to calibrate it: turn off your computer, press the button and turn on, release the button and let progress labels.
Oct 20, 2008 | Zebra Eltron TLP 2844 Thermal Label...
TLP 2844-z Flashing Red Light When I Try To Print
When the light flashes red, press the green button once. What happens then?
Oct 15, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Tlp 2844 printing issues
try powering off the printer, pressing the green button while powering back up then when u see it blink let go of the green button
May 30, 2008 | Zebra TLP 2844-Z Thermal Label Printer
TLP 2742 not printing
Go to printer properties, advanced - tools - commands
and enter: ^DEFAULT
This command reseys the prntr
Mar 17, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
1,833 people viewed this question
Top Zebra Printers & Copiers Experts
Level 1 Expert
kenneth njonjo
Are you a Zebra Printer and Copier Expert? Answer questions, earn points and help others
