Question about Whirlpool LHW0050PQ Front Load Washer
Strange noise upon initial start-up
Whirlpool LHW0050PQ0 frontloading washer
It sounds like the machine is choking itself while doing the initial draining before starting the wash cycle. Checked the drain hose and it appears to be clear. Not sure if my pump is going out or what. Machine will be four years old in October.
    Sergeant:
  • 187 Answers
try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
Posted on Jun 01, 2009
Light continuously blinking and washer does not start on whirlpool frontload washer
need more info model # or picture of data tags\
sound like door lock
Nov 25, 2016 | Whirlpool Washing Machines
My washer won't spin. There is a coin stuck inside
If the coin is in between the 2 drums but is free floating you amy be able to get it by removing th bottom drain hose from the drum but this can become a pain unless you are lucky as the coin will move with the machine tipped over. the other way is to remove the heating element while the machine is upright and use a stick or a grabber to get it out.
Dec 30, 2012 | Washing Machines
Initially, the machine was leaking water and mde a loud noise. It was turnedn off and the clothes were taken out of the washer. Two towels were placed in the tub and we tried to rinse and spin. No luck,...
sounds like you need a new u joint. The ujoint is a very difficult thing to replace. overtime the unjoint usually gets corroded and it joins itself to the shaft of the washer. This makes it very difficult to get off. It is also easier to do if you have the special tools needed to take that machine apart. If you still want to do it, here is the part number 8299753. It will cost you around 200 for the part.
Jul 15, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Washer is really loud and sounds like a grinding noise?
the main bearing has failed. big job - leave it to a pro.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 07, 2009 | Washing Machines
Whirlpool Duet 9100 starts cycle then stops & wont drain
F2 code is a drain issue. If you are not using he detergent you can cause slow draining and then you will get the code. Try using less detergent. Also, try disconnecting the power to the washer to reset controls.
Mar 24, 2009 | Whirlpool GHW9100L Front Load Washer
Troubleshooting Whirlpool Push to Start Mechanism for Washer
What kind of whirlpool do you have? is it a top loader or a frontloader. If it is a top loader is there water entering the washer? does it not agetate? Does it not Spin. If it does not wash or spin it is a possible bad lid switch close the lid. Do you hear a click? If you have no CLICK sound you have a bad lid switch.
Jan 22, 2009 | Whirlpool Push to Start Mechanism for...
Whirlpool Model LSR8233EZ1
Transmission gearing failed or coupling.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 11, 2009 | Washing Machines
Whirlpool LHW0050PQ Front Load Washer Logo
136 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
