Question about Philips Magnavox 27MS343S 27" TV
Magvx mod.27ms343s,turns on/off by self then works great for week
Blew off dust in remote area,and on/off switch area seem to help ?
    President:
  • 814 Answers
This television is showing signs of component malfunction. The turning off and on is a problem with intermittent components in the power supply circuits. You should call Magnavox customer service at this telephone number 1-800-705-200 and ask them,where you can take the television in for testing and service. This problem will only get worse and could cause major damage to you television without service.I hope this information helps you with your problem.
Posted on Jun 02, 2009
Have Singer 2000. Repaired some jeans last week worked great Today it will not pull the fabric . Feed dogs do not seem to be working. Cleaned dust ect. from bobbin area. New thread in bobbin and...
Is it possible that the machine is set to "Buttonhole"? That will disable the feed dogs so you can make the buttonhole the desired size, on most machines. Try selecting a different setting on this machine. it looks very intricate to me and seems to me it shouldn't give any trouble, so a setting is my thought.
Hope this is of help, Please rate and comment, Thank You,
Joe
Sep 01, 2011 | Computers & Internet
I Have a hampton bay ceiling fan mod. 523 342,
if you have connected power directly to the fan motor and it doesn't turn...replace the fan.  However, also check the switches on the fan as you may have bumped them.
Mar 24, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Magnavox 27ms343s tv won't turn on manually or with remote, help
If you are comfortable with tool sthere is a fuse inside the unit right where the plug goes in. I would check this first. Caution unplug it first VERY high voltage inside 30,000 volts!!!
Mar 24, 2009 | Philips Magnavox 27MS343S 27" TV
KDS-R60XBR1 Sony Projection SXRD
The lamp may be starting to go, the symptoms you describe are classic warning signs. You could unplug tv let it cool down and check lamp most likely the glass will not look clear maybe a little milky or smoky in areas..dead give away.
Mar 07, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
I just replaced the lamp and after about half hour screen goes green and blue. What is the problem?
I relaced a bulb and then my vivitek 56" started to do wierd color flickering, turns out that there was dust in the color wheel. I fixed by taking off the back and with can of air blew lightly into the color wheel area ( has tiny hole) I didn't put the nozzle through the holes. But the minute I did that a big piece of dust came out and tv is working great. Hope it helps
Feb 20, 2009 | Vivitek Televison & Video
Magnavox tv
I think I'm having the same problem dont knowif its the cale or the TV I have an old one too,gets wavy kinda rolls vertically
Jul 05, 2008 | Philips Magnavox 27MS343S 27" TV
OUT OF PAPER
1.Try downloading firmware
2.Check for driver
3.Check for LED indications on printer front panel.
4. Try removing dust between fork sensors situated below card feeder.
5. Try removing dust below ribbon sensor plate (blue led ) .
6.Do self adjustment
Hope this helps
Mar 15, 2008 | Evolis Dualys Thermal Card Printer
Need RCA univeral remote control code for Magnavox 27MS343S
Push in and hold code search button until it stays lit, then pushed the TV button, it flashes quickly. Then hit the number zero once, then hit channel up button until tv finally changes channel. Hit the mute button once to get it to store the code.
Feb 20, 2008 | Philips Magnavox 27MS343S 27" TV
Trouble w/ my Phillips 50P8341 50 IN. HELP!!!
there is most likely a prob. with the keybd. switches all need to be replaced at the same time.
Aug 22, 2007 | Philips 50P8341 50" Rear Projection...
Philips Magnavox 27MS343S 27" TV Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
