Question about Ryobi Garden
Bump head screw lost. Cannot find a rpelacement that fits.
I have a Ryobi 390r gas trimmer. The top of the bump head assembly came off and I lost the screw that keeps the assembly together. I spent over an hour with three different associates at Home Depot and we could not find a screw that will fit into the assembly. The screw hole does not look like it is damaged.
  • 1,040 Answers
Try going to an outdoor power and equipment store of some kind. They will probably have what you need.
Jim
Posted on Jun 01, 2009
  • Jim Parker
    Jim Parker Jun 05, 2009
    Were you able to find the bolt?
    Jim
I changed the string in my ryobi 725r and since then it feeds the string so fast it wraps around the shaft. What did I do wrong?
multiple failures with bump advance string trimmers - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Jul 5, 2008 - I have indeed hurled my own ryobi across the yard in a fit. ... Some heads are not designed for curved shaft trimmers or on engines under a .... the fence so thestring won't wrap around the fence instead of whipping in and out.
Sep 30, 2015 | Ryobi Garden
Repair manual for ryobi line trimmer rlt900
Jerry,
That number is not the model number for the trimmer, which always starts with RY. It is the number for the "bump head assembly" which is considered an accessory. They made 3 for this application as follows:
  • Bump Head Assembly, RLT1000, RLT900, RLT1004K
Once you determine your correct trimmer model number you can go to the link below and find your manual. Hope this helps.
RYOBI Product Manuals
Mar 29, 2015 | Ryobi Garden
How to restring trimmr line of ryobi gas trimmer
What is the model of your Ryobi trimmer? If it is a bump an cut, you just turn the big plastic screw on the bottom CCW, and take the spool off.
Oct 09, 2014 | Garden
Ryobi 26cc gas trimmer. Can't replace line. Used 1 8'' line thru slots in spool. (3'' each side). Don't understand next step. Push down spool and twist? Should spool stay level...
You line up the head with "arrows" by turning the plastic bump knob on extreme bottom. When arrows line up with the head then you insert your line through the slots "OR" you insert the line in one side and it comes out the other side. Then you have to push pressure DOWN ******* the bump head while twisting the bump head clockwise to "pull in" the string until there's only about six inches left remaining on the "shortest" piece hanging out the side. use scissors to make the lines equal in size before staring the trimmer. Hope this helps.
Sep 08, 2017 | Ryobi 30cc 17" String Trimmer Zrry30530...
Ryobi Reeleasy line trimmer head PROBLEM
sounds like the clip isn't engaging properly. For a bump and feed they have steps that lock when enough cord is set out. If the head is not locked when its on it will recoil in. Try to make sure its not sitting wrong.
Apr 20, 2017 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do u remove the bump feed spool from the bump feed string head on my ryobi gas trimmer
Grasp the outer portion of the cutting head in your left hand and turn the inner knob with your right. Depending on model, some bump knobs are threaded and some are post and notch. Use a little spray like wd40 to loosen the mechanism. It may take a firm hand, but the two will separate so that you can reload the line. Consider reloading with the .095 five sided line. It cuts much easier than the round line.
Aug 29, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Remove the trimmer head from shaft
The entire trimmer assembly (from the gearbox forward) will slide off of the drive shaft cover. On the side of the aluminum gearbox assembly, you will find a single screw. This is the "anti-rotation screw" (do not lose this). Then remove the small (approximately 1" diameter) clamp from the end of the gear box assembly and simply pull the entire cutting assembly off of the shaft.
If you just want to remove the trimmer bump head assembly, then you will need to lock the bump head assembly to prevent rotation while you are working. If you purchased this new, then there should be a small metal rod included with your accessories. This will fit in a small hole in the base of the gear box assembly 791-182193 and prevents the trimmer head from rotating.
Then proceed to remove the following items:
791-180814B (replaces 791-180814) Bump Head Knob Assembly
791-147495 Inner Reel (hold the trimmer string)
791-610636B (replaces 791-610636) Spring
791-612026 Retainer (be careful removing this so you do not inadvertently destroy it). If you intend to reuse the trimmer head. If not, then hack, pry, stab, etc.. until you mangle it enough to remove.
791-683301 Outer Spool & Eyelet Assembly should now slide out leaving only 791-612483
Spool Shaft which I will assume that you want to keep.
I replaced my entire string head assembly a couple of years ago (and subsequently misplaced it and am in fact wanting to purchase one) and replaced it with a grass-gater or similar.
I hope this helps.
Jul 16, 2009 | Troy Bilt Tb70ss Gas Trimmer
Replacing the cutting head on Ryobi string trimmer.
There is a nut above the head, place a wrench on the nut then unscrew the head from the shaft, unless yours is different from mine this is how it works. I hope this helps.
Jul 05, 2009 | Garden
Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
May 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
137 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
