Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Temp is rising in my freezer (0 to 10 in a few minutes)
My freezer is full and the temp is rising! Help!
    Novelist:
  • 103 Answers
Hi: Is it so full you blocked the vents in the back? It's possible it was going through a defrost cycle when you checked and it naturally spiked in temperature. Don't open the door every few minutes ( everybody does it) as you will dump the cold air out of it. Call Service if it isn't one of the simple things get it rolling, as it would be serious. If I'm right call and cancel the service call. I hope your problem is simple and cheap, Jeff
Posted on Jun 01, 2009
The refrigerator warning beeper is going off and the temperature is slowly rising. the freezer is working fine. it is a samsung model RB2055BB
Unplug for 24 hours and replug. After 2 hours of running, temps of fridge and freezer should be close to normal and water pan should be nearly full. If so, suspect your defrost heater as needing replacing, and note that unit will behave as-is for a few days and then your symptom will return, confirming the need for the new heater. Change the small inexpensive clip-on thermostat at the same time.
Dec 21, 2014 | Samsung Refrigerators
Why is the control panel flashing HI on my Delfield RS10550 ?
Not sure why you would want a -19 degrees when ice cream usually is about -10.
I have had some issue with their freezers not holding temp. Would have a temperature rise and cause the compressor to come on in as little as 4 minutes. Never found the cause. I would cause the compressor to come on and over heat and go out on overload. Sorry but I can not give an exacting answer. This is not normal for most freezers.
Jul 20, 2014 | Delfield Freezers
Freezer temp. keeps rising
try to turn off the freezer and adjust the temp. settings to a minimum.. Make it 20 minutes for your fridge to turn off before you turn it on. If the temp. keeps on rising, refer to your freezer manufacturer to repair the thermostat inside of it.
Aug 27, 2011 | Frigidaire Refrigerators
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Refrigerator Model TFX22KRDA. The evaporator located in the freezer ices over and loses cooling capacity. When turned off and the ice is removed, the freezer and refrigerator both work fine for a few weeks...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 29, 2010 | GE Refrigerators
My temp on my fridge is rising. It is usually on
what the problem is the ports that go from freezer to frige are all iced up you just need to defrost a few hours
Mar 12, 2010 | Refrigerators
The freezer side of our Samsung SR-2026CVW is unable to hold a steady temperature, and some times the temperature rises to 0. Unpluging the mains for a few moments seems to cure the problem for a short...
you do not say how full/empty you keep the freezer.
pad out empty spaces with any spare foam (stops air movement when you open door) could be faulty temp sensor...or auto defrost sensor .......rare.
Feb 08, 2010 | Samsung RS2630WW Side by Side Refrigerator
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
556 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
