Question about Dell Dimension 3000 PC Desktop
Dell dimension starts up then shuts down
Starts up 5 -10 seconds then shuts off with burning smell from power supply area
  • Dell Master
  • 2,404 Answers
Power supply is definitely bad. Burning smell is coming from resistors that have blown. If your machine is still under warranty then get another one from Dell. If its not then any normal 250 Watt Power Supply that has the p4 connector with it will work on your Dell computer.
Power Supply should run you between $20.00 - $30.00 depending on where you go.
Posted on Jun 01, 2009
  • 105 Answers
Power supply shot
can get power supply from microcenter
http://www.microcenter.com/single_product_results.phtml?product_id=0293459
or take your out REMEMBER where plugs go and buy a new one cheap
Computer shouts down in 15 to 20 seconds after starting
The specs say the PSU is ATX compatible. Whether that is for the connector only or for the whole power supply is something you will have to determine.
If you have an ATX power supply handy (like in an old computer) give it a try. This one is only 300 Watts so it won't likely be expensive to replace.
Have a look at: http://www.techspot.com/community/topics/dell-dimension-1100-shuts-down-after-20-seconds.135987/
Aug 28, 2012 | Dell POWER SUPPLY Power Supply
Dell Dimension 4400 NEVER froze (8-9 years old) until a week ago - kept freezing at start-up - - had to interrupt power SEVERAL times to restart - - tried to power up yesterday - - make a slight sound,...
You need a power supply! Go to Amazon and search for one that is the same specs as yours. Fairly easy to replace, don't use your old one anymore, it could be dangerous.
May 05, 2011 | Dell Dimension 4400 Power Supply ** FREE...
My Dell Dimension 4550 starts up and after about 30 seconds shuts off. It does not matter if I boot in safe mode or normal and I have disconnected everything but the monitor, keyboard and mouse.
If the computer shuts off completely like someone pulled the plug from the electrical outlet, it is probably your power supply. I would first check all the main cable connection from the power supply to motherboard. If the problem persists, swap out the power supply. Thanks.
Mar 18, 2011 | Dell Dimension 4550 PC Desktop
My dell dimension 4600 won't boot up and when you try to turn it off with the button it just starts back up.
It sounds like a back-up was started and now your system is trying to complete the task before it shuts down. You can turn it off by holding the power button down for 10 seconds. This will cause the power supply to shut down completely. You will lose any unsaved data and it may corrupt your back-up.
Mar 25, 2010 | Dell Dimension 4600 PC Desktop
Dell Dimension 2350. After I shut it down and try
Check that the computer is not hibernating rather than shutting down. It will be in the power settings.
Mar 06, 2010 | Dell Dimension 4600 PC Desktop
I have a Dell PC-5251-2DS power supply. Am getting vertical stripes on the screen and the machine dies. Have a slight burning smell which makes me wonder if its the power supply. Would you concur?
The burning smell could be coming from the video card. Stripes on the screen indicate faulty video memory, shouldn't have anything to do with the power supply.
Jun 26, 2009 | Dell (PS-5251-2DS) (M0148) 250-Watt Power...
Computer has shut down and can not re-start
The Dell 8300 does not use industry standard parts. You need Dell specific parts in order to replace the fan. Here is a link to a replacement fan shroud assembly for your Dimension: http://www.discountelectronics.com/index.php?l=product_detail&p=845
You may be able to find cheaper if you do a Goggle search and dig deeper. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 14, 2009 | Dell Dimension 8300 PC Desktop
Won't Turn On
Yes, It shows the board is getting power (maybe not enough though)
Since I can not see your computer, run through this checklist from Dell, Let me know how you make out.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=40D4258B12DC06C9E040A68F732810A7&treeid=011360B8243248349C306481A954B356&Query=bm8rcG93ZXI=&SystemID=DIM_P4_4600&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=true&dl
I would without seeing it that the PSU is bad.
Dec 09, 2007 | Dell Dimension 4600 PC Desktop
Hard drive and cd drives still on
Locate Power Wakeup option in modem/LAN in BIOS and disable them, if you have "power wake up" enable for LAN/modem your computer will be switched on for remote network command.power wake up setting are located on BIOS.
Dell Dimension 3000 PC Desktop Logo
1,028 people viewed this question
Alun Cox
