Question about Frigidaire GLTF2940ES Front Load Washer
Washer has water but doesnt spin frigidaire gl2940es
I have water just sitting it wont spin or drain. i just get a humming noise. what can I do?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 120 Answers
Something is stuck in the pump. Remove the hoses and remove the items. It will probably be a coin.
Posted on Jun 02, 2009
Frigidaire Front load Washer Does not spin (Drains fine, Water comes in fine)
Hi John - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. The humming noise is mainly caused due to the drainage hose/pump possibly being clogged and needs to be cleaned. If not, the washer may be experiencing another possible issue with the faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
May 02, 2013 | Frigidaire FTF530FS Front Load Washer
My frigidaire affinity front load washer ATF6000 will agitate but wont spin
Hi burwellkaren - Is the washer making a humming noise? If so, either the drainage hose or pump is clogged and needs cleaning. If not, then the unit may possibly be experiencing an issue with the control board not communication correctly, faulty pump, timer, door lock assembly or something more severe like a damaged tub. I will personally recommend contacting a certified technician to narrow down the precise issue before investing in parts that may or may not be the root cause.
Mar 08, 2013 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washer ftf2140fs2 lights on the right side keep beeping washer wont start
Hello 2cats - First, is the drain pump making a humming noise? If so, the unit could possibly have a restriction in the drain line. Try setting the cycle to spin only and verify if water pumps out. Other possibilities could be a faulty door lock, timer, pump, or control board not communicating correctly. In this case I would contact a professional to move forward accurately to properly diagnose and repair the washer.
Feb 28, 2013 | Frigidaire FTF2140F Front Load Washer
Wont spin
Hello Trish Mills - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Contact a professional to move forward accurately.
Nov 17, 2012 | Frigidaire ATF6000ES Front Load Washer
Wont ring water wont drain
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. Supposing that it does not, the unit could possibly be experiencing an issue with either the pump or timer. Contact a professional to move forward accurately.
Nov 03, 2012 | Frigidaire ATF6000ES Front Load Washer
Why my frigidaire top loader wont spin?
Hi - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Oct 18, 2012 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire Washer wont drain
If lid lock is bad the tub will not spin properly. Unplug, remove front and look at the lid lock closely. Let me know, Thanks, Sea Breeze
Jan 08, 2009 | Frigidaire GLWS1233A Top Load Washer
Frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
220 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
