Minolta DiALTA Di183 Copier Logo
NOEL BIRKLAND Posted on Jan 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW TO ENTER SERVICE MODE ON LJ 4730 - Minolta DiALTA Di183 Copier
Norman Weimar
Level 3:
  • Minolta Master 7,035 Answers
  • Posted on Feb 22, 2015
Norman Weimar
Minolta Master
Level 3:
Answers
7035
Questions
Helped
1910506
Points
11959
HP Color LaserJet 4730 Multifunction Printer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2answers
Hp 4730 fuser reset
Anyone with information on how to reset the Fuser page count without chanigng the fuser on HP 4730 MFP? The fuser in the unit is in very good condition and replacements are not cheap. Any help would be much appreciated.
3helpful
CREATIVE SOUND CARD CT 4730
CREATIVE SOUND CARD CT 4730 if you do not have a sound card driver try use the windows xp service pack 2 installer go to device manager right click and update the driver details. then restart your pc.
I just wanna know that where is acer service center in thane(w)...
Click on the link below and enter your model number and the repair center information will dispaly on the screen
http://secure2.tx.acer.com/FixMyAcer3/FixMyAcer.aspx
You can also call us at 1-866-695-2237
1helpful
Wrong firmware installed in HP LJ 3050
I am very sorry to have to be the bear of bad news. Usually doing a failed firmware update (or wrong firmware version) you have to return to factory or have a local computer printer shop that deals in HP printers repair this firmware mixup. There is sometimes a firmware recovery mode that can help however You would have to contact HP and ask them how to get into firmware recovery mode.
Sorry hope this helps answer your quesiton.
Steven.
2helpful
Not sure whether Athiros is the driver for WLAN ACER ASPIRE 4730Z
Here is the link for all drivers for your Laptop XP/Vista: Try all this drivers
WLAN_Broadcom_V4.170.25.19 Driver for Aspire 4730 4730Z Win XP
WLAN_Intel Shirley Peak_V12.0.0.78 Driver for Aspire 4730 4730Z Win XP
WLAN_Ralink_V1.1.5.0 Driver for Aspire 4730 4730Z Win XP
WLAN_Atheros_V7.6.0.239Driver for Aspire 4730 4730Z XP
http://komku.blogspot.com/2008/10/aspire-4730-4730z-windows-xp-and-vista.html
2helpful
2answers
My remote control to RDR GX3 Sony DVD recorder does not function. When put on TV it works but does not work on DVD setting
Please change command mode on dvd recorder remote as it has 3 modes, dvd-1, dvd-2 and dvd-3. command mode switch is located at bottom part of remote.
DVD Recorder default command mode is DVD-3
3helpful
Canon F60 waste ink near full message
Hi. I actually had to reset the waste ink volume counter on my F60 and found a solution posted by NerdRUs that helped me. So I copied and pasted it below:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
LJ 2840 installation on XP PRo
Check that the firewall either windows or other is not active and not allowing you to install drivers. Also if your computer is in user mode and does not have the right to install drivers login as administrator mode and install drivers through there.
Once deactivated firewall install new drivers should be OK then.
Thanks J
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
