Question about Canon PIXMA MP610 InkJet Printer
Rear Paper Jam - No paper present.
Have a Canon Pixma MP610. Screen states that there is a paper jam in rear of unit. No paper jam found. When turning on printer, paper is fed through, but stops short of clearing. Have to manually pull it out. Cannot get rid of rear paper jam message. Have tried to clean rear rollers from printer request, but is over-written due to paper jam. Help...
  • Anonymous Mar 15, 2014
    getting paper jams have cleaned printer and paper still jams st
  • 256 Answers
Look for a small piece of paper that may be stuck in the switch indicating a paper jam.
Posted on Jun 01, 2009
There was a paper jam. I got the paper out but now error message 6A00 appears in the screen. I have tried to turn off and on.
The error code means paper path jam.
Inside your printer a paper path sensor has been activated indicating paper jam so the printer will give off a 6A00 code.
So please check for any stuck paper, debris
The offending item needs to be removed or the purge unit needs replacement.
Also clean the purge unit out make sure all is clean
May 11, 2010 | Canon PIXMA MP610 InkJet Printer
Paper jam (e3) BUT no paper jam
make sure you open all check points, if yours has a rear feed through, look in there also. it only takes a tiny piece of paper to cause it to say that. use a flash light, have had to use one to find several that way.
Feb 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Problem with Canon MP600
I had the same problem with my Canon Pixma MP610.
After stripping the printer down I found there is a lever in the path of the paper that operates a photo electric sensor. This can get stuck in the wrong position. To reset it get a sheet of A4 paper or (better) card fold back a 1 cm strip on the top edge of the paper and press it down flat. Open the rear cover and insert the sheet folded edge first and folded flap upper most over the top of the upper set of rubber rollers. Push it into the machine as far as it will go and then withdraw it. You should feel a little resistance or here a click as the lever is reset. You printer should now work.
Several hours of frustartion and foul language have brought you this fix. I hope it works for you.
Regards
Jon
Jan 03, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Paper jam
This model has 5 places where you might encounter jammed paper. Since you said you cannot see it, I suspect that it may be one of the following:
1) Inside from the front - (This is a similar to accessing the print cartridges). Raise the scanning unit until it stops (cartridges move to the center). Open the two inner covers. Gently clear the jam. Try not to touch the printer components. Close both inner covers, lower the scanning unit. Press <OK>
2) Inside transport unit - Open the rear cover. Remove the jammed paper or any bits that you may find. Close the rear cover. Press <OK>
Dec 19, 2009 | Canon PIXMA MP760 All-In-One InkJet...
I continue to get error message 3 from my pixma
E3 is paper jam.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output)
is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service, because in most case when have a paper jam it's under withe rollers and printer must be disassembled.
Nov 24, 2009 | Canon PIXMA MP160 All-In-One InkJet...
3 yellow flashes, then 1 green on a Canon PIXMA Ip4000
3 flashes is a GREAT symptom report. We need some more than that, but it does give us a direction.
If this is a "Service Call Error", it will be accompanied by an on screen message that includes a "6000" error code.
Here are the possible solutions....
- Timing sensor unit (QM2-1213)
- Timing **** disk film (QC1-4833)
- Feed roller ***'y (QL2-0598)
- Platen unit (QM2-1215)
- Logic board ***'y (QM2-1548)*1
- PAPER FEED MOTOR (QK1-0550)
These solutions are not for the novice, but are user servicible for many out there.
If this is a "Operator Call Error", it will also be accompanied by on screen error codes
Paper jam. [1300]
Paper jam in the under guide. [1304]
Paper jam in the rear guide. [1303]
Solution: Remove the jammed paper, and press the Resume/Cancel
button.
OR
Front door closed. [1250] Open the paper output tray.
Get a free copy of the service manual by contacting me at www.Equipmentcity.net
Sep 29, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon MP 510 paper jam
I had the same problem and found a small coin in the back feeder. Remove the back coverplate and tip the machine onto its back and give it a good shake. You might be surprised at what falls out.
Apr 30, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Paper jam
I had a paper jam issue on mine and it was due to the fact that I had the door open on the back of the unit.
Stranger things have happened i guess :)
Jan 22, 2008 | Computers & Internet
Clear Paper Jam error -- but there is no paper jam!
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects...
Apr 16, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP610 InkJet Printer Logo
1,092 people viewed this question
old marine
old marine
