Question about Denon AVR-3806 Receiver
Video output not working, used to work fine
Can't identify problem.  cables appear to be secure.  was working for years.  works sometimes, not others.  i think it may happen when the unit has been on for a while (playing music or something else)...could it be overheated?
get sound on all components...dvd, tv, vcr  but most of the time i am getting no video.
5 Suggested Answers
  • 979 Answers
SOURCE: Denon AVR-2807; no sound from tv/dvd, but works for wii/radio
Try using the original remote.
Posted on Mar 09, 2008
SOURCE: no HDMI video output from AVR-588 receiver to plasma TV ???
You can also use a digital coax cable (color orange) to go into coax 1 for DVD coax 2 for cable box. Just make sure to set the coax in input settings. The coax cables are a little cheaper than the optical cables and work just as well.
Posted on May 10, 2008
  • 119 Answers
SOURCE: Denon AVR-587 Television input stopped - no sound
try plugging another device into the tv input and mank sure you have the input mode is set to auto if you still have no sound those inputs are gone
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-587&imageField.x=106&imageField.y=8
Posted on Feb 25, 2009
SOURCE: Denon AVR-2807 HDMI out signal
i seem to have a similar problem with my Denon AVR 4310CI . The output to my LCD TV just went green . On checking with some people , they suggested resetting . it didnt work . Any probable reasons
Posted on May 27, 2010
Tv screen turns black and red when playing through pioneer receiver
Usually when I hear of solid colors that display on a TV, my first solution would be to change the cable. We know your DVD player is working as you connected it straight to your TV and you report no problems. I assume you are using a composite cable (red, white, and yellow) Red and White being the Audio and Yellow your video.
But since your player works...and your tv works under the same input, then the only other issue would be the output cable from the receiver or the actual composite input or output connector is faulty.
try a video game system in place of the dvd player through your receiver..if it happens again, then change the receiver's output cable...if it still persists then your reciever's output connector is faulty.
I hope this helps.
Aug 09, 2012 | Audio Players & Recorders
Denon 1312 receiver composite video inputs do not work.
I'm having the same problem with my Wii output. The manual for the Denon AVR-1312 says that analog video signals (i.e. component/composite outputs from the Wii) are not converted to digital video signals (i.e. HDMI output from the rcvr). I'm running only HDMI to a projector, so the video signal is essentially lost. The fix appears to be to run an additional composite cable all the way to the projector. Sounds like your fix is the same. No Wii tonight! :(
Jul 07, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
No DVI video output from dell xps 210
It sounds like your video card has gone out. Is the VGA and DVI ports on the same video card? If so the card is probably bad.
Mar 25, 2012 | Dell XPS 210 PC Desktop
Have sound but no picture
Hi
First thing to go is try a different television and a different video cable if still no picture is displayed on television (screen is blank) You seem to have a problem with the video output from your nintendo wii.
NO PICTURE
1 Turn your television to the correct video input channel. For many televisions, you can press the "Input" button until you see the Wii start up screen.
2 Ensure the power cord is securely plugged into the DC jack on the Wii and the opposite end is plugged into a working electrical outlet. Press the "Power" button on the Wii and wait for the indicator light to turn blue.
3 Secure all of the Wii component cables to the "Video In" jacks on the television. In addition, make sure the opposite end of the wire is fully plugged into the Wii.
Dec 30, 2011 | Nintendo Wii Console
Computer vga cable/ sansui tv problem
Hello
Nvedia signals cannot be porcessed by Sansui Tv. You have tow options before you to connect your self assembled computer to this tV. The first one is try by reducing the resolution f VGA output. for that, go to Nvidea control [normally will be displayed at the right end of the taskbar] and chage relolution there. By default, the resolution will be 1024/768. Select it to the lowest; 800/600. If the TV display it, just advance it to the next highest; 960/600.
If this does not help you, there is no other way than change the computer's video card to any other, which works on Windows Video Drive. Can be bought from local computer component market, insert it to one amoung the free PCI socket of the computer and do the next proceedings to change over video output from on board video out, and feed this video signal to yur TV. OK.
Nov 01, 2011 | Sansui HDLCD1908 19 in. LCD TV
Feb 06, 2010 | Denon AVR-2805 Receiver
H Slimline New Graphic Card-No new DCI output-Yes old VGA output
you are missing nothing actually the graphic card over rides the onboard graphics and you have to use the graphic cards output ,only one hardware at a time for pci devices
May 08, 2009 | Computers & Internet
Screen just went black
Think your set tuner is bogus. The other tuner that you used should work, but if it is not a cable tuner configured to your system it will not work either via the rf outputs or the audio video outputs. If that cable box works with another set then you have a real head scratcher on your hands.
Mar 24, 2017 | Sanyo AVM-2756 27" TV
Denon AVR-3806 Receiver Logo
170 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
