Question about Maytag Neptune MAH5500B Front Load Washer
Door lock mechanism
Door does not close tight enough to engage the automatic lock mechanism - the machine makes several attempts to lock and then the FL clode (failure to lock) code is displayed.
  • Anonymous Mar 18, 2014
    door attempts to lock but the locking system does not work
I had this problem also with my Maytag Neptune TL. The door lock would click muptiple times before displaying the FL code. I was able to fix this by removing the left door look(the one with the door close sensor) and cleaning the 2 metal pones on top of the left door mechanism, which had rusted and no longer was able to since the door closed. I use a nail file i sure eaither that or sandpaper will do. After that it went through the whole cylce without stopping or displaying the "FL" code.......hope this helps
Posted on Jan 16, 2013
  • 6,784 Answers
Hi. this is a failed Door lock mech that should be replaced asap if possible. This will run you about 55 to 60 dollars tops.
It is a good rule to replace the door lock hoop assembly along with the door lock latch assembly at the same time. make sure the alignment it correct during the installation.
Posted on Jun 01, 2009
Electrolux washer error code E42
The E42 error indicates a problem with the door lock mechanism. If the door was closed, did you hear the lock attempt to engage? If you heard the lock, check the door strike. If the strike is good, replace the door lock. If the lock didn't attempt to engage, check the wiring between the door lock and the control board. If the wiring is well seated and the wires have continuity, replace the door lock. If the replacement lock doesn't solve the problem, then replace the main control board. (You should find a diagram with the wiring inside the unit near the control board.) If you have broken wires in the wiring harness, replace the wiring.
Please add a comment with the model of your washer if you want me to point you to any parts/price lists.
I hope this helps.
Dec 19, 2016 | Electrolux Washing Machines
Hatch closes tight then opens
The latch is not engaging all the way. It temporary does than release part way. It is similar to a hood latch. When you close hatchback the l?tch mechanism is supposed to close around the pin and lock tight for some reason your latch spring back a little. Could be the spring or locking clip. Might need a new latch mechanism. Easy to replace. Car won't lock because mechanism is broken
May 02, 2016 | Cars & Trucks
Amana he washer door won't close
Bad lock mechanism, without proper model number I can't give accurate instructions.
Jun 22, 2012 | Amana Washing Machines
Automatic door locks
is i lockingt after you start it... and does it relese when turn off
May 21, 2012 | 1999 Volkswagen Passat
The door on my kenmore elite dishwasher will not close or lock
Hi, the "latch keeper" has gotten out of alignment. You'll need to adjust it.
All you'll need is a Phillips screwdriver to fix this. Open the door and look at the "latch keeper" (it's not on the door, but on the frame). It's the thing that the door lock/latch grabs on to when you try to lock the door. There are 2 screws holding it in place. Loosen these, pull the keeper toward you a bit and tighten the screws to lock it in. Now try your door.
This may take several attempts to get it just right, because you want the door closing tight enough so as not to allow a water leak and loose enough for you to close it easily.
Jun 26, 2011 | Dishwashers
The door to my washer won't shut tight enough for the lock to engage. We replaced the locking mechanism on the door itself and it will run if we hold the door shut.
A possible simple repair can be attempted at the hinge of the door place a towel/washcloth/or other suitable clothing to add a soft jamming space and GENTLY!!! push the DOOR in an attempt to close it, place one hand at the normal closing area and the other opposite 1/3 of the way from the hinge. If there is not enough wedge fold over garment at hinge and make it thicker do this until door will close properly.
Apr 02, 2011 | Frigidaire 14 Cycle Tumble Action Washer
My machine is showing the code FL machine has problems locking. How do I resolve this problem
Your Maytag Neptune Washing Machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
Dec 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a 1997 Jetta and all of a sudden the drivers door will not engage when trying to close the door. The door is not catching. please help. linda
I had the same problem on mine.
Tyr this: Use the interior handle and lift it. Hold it and, with a pencil, you need to lift a little part on the lock system. Once this is lift, the door will engage. Now do not lock your door before closing your door!
Jun 17, 2010 | 1997 Volkswagen Jetta
Latch on my Kenmore dishwasher model# 363.14582100 won't close
Sharon,
The "latch keeper" has gotten out of alignment. You'll need to adjust it.
All you'll need is a phillips screwdriver to fix this. Open the door and look at the "latch keeper" (it's not on the door, but on the frame). It's the thing that the door lock/latch grabs on to when you try to lock the door. There are 2 screws holding it in place. Loosen these, pull the keeper toward you a bit and tighten the screws to lock it in. Now try your door.
If you have any questions, post back and I'll try to explain in better detail.
SG
Apr 01, 2009 | Kenmore Dishwashers
Washer wont engage
The door may not have been fully closed. stop/clear cancel the cycle. ensure door is fully closed and attempt to resart cycle.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Feb 08, 2009 | Kenmore HE2 Plus Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
417 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
