Question about HP Pavilion M8530F Phenom X4 9550 5GB DDR2 Memory / 750 GB Hard Drive/ Memory Reade... PC Desktop
Which input do I plug the speaker cord into & where is the volume control?
Which input do I plug the speaker cord into at the rear of the computer?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Look for the green jack on the back of the computer, that should be where you plug the speaker into.
  • 42 Answers
The port should be light green.
Posted on Jun 01, 2009
BA 635 subwoofer stopped working. green light in the back does not light up anymore. Can it be the power supply cord? It this common? Solution? How can I check if it is a power cord issue?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Apr 27, 2011 | Boston Acoustics BA735 Computer Speakers
My logitech z-640 speakers have quit out on me. i think there's a short in the cord where the 3 jacks are. they are awsome speakers and i just wanna fix them. what should i do?
well you &hash39;s why do you think there is a short in the cord did you hear static?
if you are having problems with your sound
also
hope this helps
Apr 14, 2011 | Logitech Z-640 Computer Speakers
I have 2 Kustom KPC10MP powered speakers - very new. One has developed a hiss that increases with volume, regardless if there is signal going into the speaker or not. This is a new development as of today....
Hopefully you were powering ALL interconnected equipment from the SAME receptacle. People can destroy the input circuit of powered speakers by plugging them into a receptacle at the stage and then powering the mixer from another receptacle... Pro's know to power ALL interconnected equipment from the same source, be it a receptacle or a power conditioner to avoid ground bounce damage to equipment. They carry power from the stage back to the mixer on an extension cord. You may have had a static discharge that blew one side of the balanced input of the speaker. The parts are inexpensive, however the labor to get at the amp is usually not fun. I have the dual 10 powered Kustom's and one gets at the POWER amp via removing the speaker after the grille... HOWEVER that is to get at the power amp. The Preamp is probably the failure and it is right at the input plug area and you can get at that by removing the panel with the plugs and power switch and volume control.
I don't have the schematic. Look for shorted RF bypass caps on one side of the balanced input circuit and possibly a damaged input op amp.
Apr 06, 2011 | Kustom KPC10MP 10" Powered Monitor Speaker
Hi I was wondering if You could give Me an explanation to Why My speakers May not be working. They are not bent or cut on any cord and the rear right, rear left and front center all have stopped working...
also
hope this helps
Mar 27, 2011 | Logitech X-530 Computer Speakers
My B/A 735 speakers were working fine then a hum started for a day or 2 & they totally quit working. Power supply is OK & other speakers work on my computer. Where can I get the control board...
also
hope this helps don
Mar 11, 2011 | Boston Acoustics BA735 Computer Speakers
Do not know how to connect my kappa 60.5cs to my pioneer cd player do they have to go through an external amp?what do i do with the power plugs on the oppisite side why are there 2 per speaker
You need to run RCA cables from the CD player to the CD or AUX input on your amp / receiver unit. If you have a standalone amp, you need some way to control the volume. Basically, if you have a volume control on the front of your amp, you're OK. If not, you should also have a preamplifier that the CD player feeds first.
From the amplifier, then, a single pair of speaker outputs feeds a single pair of inputs on your speakers. The reason for two jack sets on the speakers is for "bi-wiring" or "bi-amping", not necessary for basic stereo reproduction.
So -
CD red/white RCA out -> preamp/receiver red/white CD/AUX input. Amp speaker output (red + / black -) to one red/black input pair on the speakers. An input on the speaker is side by side...
Keep the red to red, black to black when connecting the speakers, or you will wind up with poor sound and weak bass.
Jan 18, 2011 | Infinity US-1 Main / Stereo Speaker
I have a KLH bassbite II sub, not sure how to connect it to my receiver. Can you help? There are 4 wire amp inputs and 4 speaker wire outputs which I am assuming are right and left channels. There are...
Forget the 4 wire inputs on the sub as you have pointed out. use the low mono input only.this can be plugged into any audio out connections at the amplifier.so it is one rca/low wire from sub to amplifier then plug in power cord and adjust volume as desired.
Mar 06, 2010 | Audio Players & Recorders
Just wondering what the power supply output JBL Media 3 Speakers
I have a pair of Media 3 JBL computer speakers. I am using a generic 12V DC adapter rated at 1000mA with a positive tip polarity, and it works fine.
Aug 15, 2009 | JBL Audio Players & Recorders
P4500 yamaha amp
first check your input cable-disconnect it and check if the problem finished---you will have a problem in input(cable or device)-start with another cable then your input device.
if the problem still check your out put cables(speakers cables)for short circuit or touch the bare wire with amplifier body.-try to clean volume controls with spray contact cleaner---confirm good connection in amplifier rear and in speakers rear.
Aug 25, 2008 | Yamaha P4500 Power Amplifier 2-Channel
Using headphones with Logitech X-230 speakers
I really don't know, because some of the newer gadgets come with fixed volume control due to law suits, ect. Try to see if you can bring you TV menu up and see what the sound setting is.
Dec 25, 2007 | Logitech X-230 Computer Speakers
HP Pavilion M8530F Phenom X4 9550 5GB DDR2 Memory / 750 GB Hard Drive/ Memory Reade...  PC Desktop Logo
56 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
