Question about Kicker SX650.1 650W Mono-Block Amplifier w/Remote '04 Series
I cant get power to the amp, everything is hooked up right, i replaced the power cord fuse... what else could be wrong,...??? the green led light is off and i tested to volts on the remote terminal and it is at zero how do i fix this
  • 87 Answers
Check in this order:
  1. Battery connection
  2. Fuse at battery
  3. Ground wire at vehicle
  4. Bat. and ground at amp
  5. Remote turn on lead should read 12v
If you have no power at the turn on lead pull deck and see if it cam disconnected, should be blue w/ white strip.
Posted on Jun 02, 2009
Red light on on amp
take speaker wires off amp if the lit is green then speaker are hooked up wrong or blown.
Mar 29, 2014 | Pioneer GM-5200T Car Audio Amplifier
Computer was shut down and power turned off. When i restarted the system the printer and monitor came on but the tower is not getting any power. cords are all plugged in and checked outlet works. seems...
If the outlet is good and the cord is good, you may have indeed blown the fuse in the power supply. That is the only fuse. The fuse in the power supply is usually "hard-wired". Not necessarily, but usually. You would need someone familiar with them to replace it if it is blown.
Some computers have a green LED on the back of the computer near the power cord. Do you have one? Is it on? You can also look to see if the small green LED is on on the motherboard.
If you get no indication of power, the power supply is probably gone. A new on is about $25 and pretty simple to replace.
Hope this helps.
Thanks for using Fixya.
Feb 20, 2011 | HP Pavilion a705w PC Desktop
I just got a sony xplod 1000 watt amp i got everything hooked up and when i turned the key the power light chaned from green to red. i check over the amp again and again, i cant find any thing wrong........
Try disconecting all speakers from the amp, turn it on after and if it stays on red it sounds like it had kicked the bucket. if it stays green start from their and check all of your wires for shorts (speaker wires) again. hope this helps...
May 08, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Kicker zx750.1 Amp in Protection Mode (Red LED)
My kicker amp zx1500.1 keep going in protection mode I unhooked the sub speak wires and put the ACR cords back in and it didn't go in protection mode what next
Mar 18, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
Amp LED light turns on then off
You need to use a multimeter to confirm that you have both B+ and remote voltage at the amp.
Oct 28, 2007 | Sony XM-2200GTX Car Audio Amplifier
LED power protection light not turning on
Check the fuse on the amplifier; if it's good, then you need a multimeter or voltmeter for further testing. With the meter's black probe on your amp's ground terminal and the radio turned on, both the power and the remote terminals should test at about 12 volts. If neither terminal shows voltage, you may have a problem with your ground connection; if both do, there's a problem with the amp.
Feb 20, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Whats wrong with my lanzar amp
check ur ground wire , it might not be good ground, secondly check ur fuses..
Dec 25, 2006 | Lanzar HTG264 Car Audio Amplifier
Kicker SX650.1 650W Mono-Block Amplifier w/Remote '04 Series Logo
52 people viewed this question
Top Kicker Car Audio & Video Experts
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
