Question about Coleman Mach 15 Air Conditioner
Not putting out cold air
The compressor sounds like it is running but after an hour no temp.change from intake. I placed thermo. at nearest duct. inside the vent. It is a rv roof unit. It sat for two years before being run. I,ve looked everything over and all looks ok. Next step measure line voltage? how? Then compressure amp? w/ outside ambient air temp. To calculate RLA? Any guidance would be helpful. Thanks my unit comes on fan and compressor seem to work and sound ok but dose non cool i have an auto repair shop and am familiar with air condishing system was going to check if it was low on freon do not see a valve or port is there a place to check freon level
  • 378 Answers
In car airconditioning system there is a filter with glass window where you can see if the gas is bubbling if so then your system have no sufficient freon gas.
Posted on Jun 01, 2009
I Have a motor home that has a Red ,Yellow Blue and Green wire someone has cut the wires and the coleman has yellow,white,green and a brownand white striped wire. What goes back to what
Posted on Jun 20, 2009
Ac compressor wants to run with the thermostat turned off?
Either your thermostat is shorted or the primary wiring to the contactor is shorted or even a stuck contactor.
Good luck,
Marty
Aug 24, 2014 | Dometic Rooftop RV Air Conditioner
Runs/cools great unless outside temp gets in high 80s
try replacing capacitors. or communication cable issue to that a/c
Jun 25, 2013 | Dometic Rooftop RV Air Conditioner
I have a new motorhome and the air conditioner only reduces the inside air temperature by 2 degrees on a hot day. e.g. outside air temp 26 degrees inside temp 29 degrees. After 2 hours of a/c running with...
Can you tell me what size/make of motorhome you have? Certainly doesn"t sound right to me, and I've been working on them for over 15yrs. Whether it's a 13,500 BTU or 15,000 BTU, it should be plenty as long as motorhome has any insulation at all. I assume you have central air from ceiling?
The manufacturer usually states that the AC unit will supply 20F below ambient.
Is compressor staying engaged all this time?
May 22, 2011 | Dometic Rooftop RV Air Conditioner
2002 Ford Escape V6 4WD A/C works but while driving long distance >100 miles and while driving at speed (70 MPH) the HVAC [set to A/C or Max with the temp all the way cold], changes on its own and...
Sounds like you are losing vacuum to the HVAC system control or the mode control switch is defective. When you have this problem you will most likely find the air is coming out the defrost vents as that is the default flow when vacuum is lost to the system.
Mar 15, 2017 | 2002 Ford Escape
Stops blowing air
remove cover at ceiling so you can see in at fins and see if they are frosting up bad. If they are, I suspect during AC installation, they didn't open up ducts on discharge properly and air flow is restricted, which will cause freeze up, especially if low flow from discharge ducts. I'm assuming it is a ducted system. You may have to remove or drop down entire ceiling assy, to see if the ducts into ceiling have any blockage. Sometimes they don't cut rubber roof material back far enough, or misaligned ducts and cause restricted flow to ceiling vents, which will cause unit to frost up, which kicks out compressor until frost is melted, then compressor kicks back in and cooling happens again.
Apr 06, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm RV air conditioner inadequate cooling
The rule of thumb is 20F difference (lower) than ambient temperature. Most manufacturers will tell you 20 F degress is about normal. In your case it does sound a little warm, but I need to ask, sorry. Was it working o.k. before in same basic temperatures? Have you cleaned coils & fins good on Evaporator & condenser recently? Have you removed filter inside & cleaned it as well, and looked to see if coils are frosting up by chance? Is this a ducted or non ducted system? I'm guessing on a 5th wheel, it is ducted, so make sure you have good discharge on all of those as well. Any blockage or restriction on the discharge side will also cause the problem. Keep me posted on what you find.
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Whirlpool Dryer Does not dry
Its the thermal fuse. when you jump or, by-pass the cycle thermostat, you are basically by-passing the fuse as well. replacing the thermal fuse will fix thsi issue.
The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Rv air conditioner leaking
I have the same problem....it is a negative pressure problem holding water inside the unit until it overflows the pan and runs into the duct system. why this occurs....I don't know....I cant find a problem with my air return, but as soon as you turn in off, the water comes gushing out the drains on the unit. I resolved this....temporarily....by twisting up a paper towel into a wick, and placing one end up into the drain tray, with the other end lying well out into the exterior case. This lets the water wick out and keeps the tray drained. I don't understand the problem and don't know what the permanent fix will be, except maybe cutting a hole and placing an intake vent directly below the unit.
Jul 16, 2008 | Dometic Rooftop RV Air Conditioner
Whirlpool electric dryer
sounds like something getting to hot, perhaps clclyng thermo not regulating temp properly, although cleaned vent, when you pushed it back ito place did you crush or hkink line? peek over top and check
Feb 27, 2008 | Whirlpool GEW9250 Electric Dryer
Coleman Mach 15 Air Conditioner Logo
256 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
