Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Philips Projection tv will not turn on
I went to turn my tv on and it will not come on. I've checked all the cords and everything is connected and should be working.
  • 4 Answers
Not trying to offend you here at all, but ....
1. Plug something else into the same outlet and verify that the outlet works.
2. Look at the power cord for any damage like wear and tear near either end of the cord.
3. Once its plugged in see if you can turn it on using the power button on the front panel (not the remote)
4. If it came on using the power button then there is not a problem with the TV.
5. If it did not come on then Sorry I can't help.
6. If it did come on then make sure the "tv" button near the top of the remote (assuming its the original remote) was pressed before pressing the power button on the remote.
Posted on Jul 09, 2009
Philips model 37PF7320A won't turn on
The power supply regulator section is not working properly. It will be best to replace this board as card basis rather than trying to make it right. Philips have used some special numbered components there, which are very difficult to get from open electronic spare part market. Contact the nearest authorized service center for Philips to buy a new board.
Aug 24, 2012 | Philips 37PF7320A 37 in. HD-Ready LCD...
Changed color setting then tv went out, clicks no picture
Likely you tried to adjust it too far and now have a shorted convergence IC---simple way to prove or disprove:
locate and unsolder completely all the pins on both chips (most use two) and see if set comes on--will look bad but if it comes on the chips are your problem---most of these sets (like yours) also have two fuses for this--if blown set will come on so we can say they are likely ok.
if further information or a question press the "make a comment" button on this page.
Mar 25, 2012 | Philips Magnavox 51MP392H Rear Projection...
Does not turn on
I have a p52929 rca 50" PROJECTION TV. THE OTHER DAY IAS TRYING TO RESERT THE COMCAST BOX, THE TV WAS CONNECTED HERE, SO I UNPLGGED THE CORDS, WHEN I WENT TO TURN BACK ON IT WOULD NOT TURN ON,THEN I CONNECTED AGAIN AND IT MADE LIKE A SPARK SOUND. ON THE POWER SUPPLY CORD.DO I NEED TO THROW AWAY. PLEASE HELP
Apr 18, 2011 | Philips Magnavox 9P6034C 60" Rear...
Projection TV Phillps 60PP9202/17F, bought 2004. Was watching and suddenly the picture went out. All connections are good and components work. Can you help?
Hi.
If there is no power at all, then it is either the power cord or power board inside the TV.
If after the fault the TV went in standby and does not wake up, then the TV is in protect mode.
In protect mode higher voltages from PSU gets shut down and TV remains in standby.(see also Why my TV does not start up and remains in...)
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Then connect powr
If that does not work, and you keep having the TV in protect mode, it means that there is a fault.
In that case call the support number listed on Philips user manual to arrange repair.
If you are a technician I can try locating parts, service manual and giving more directions. Common faults that affect a Philips rear projections are convergence, PSU board, lamp and ballast assembly.
Regards.
May 28, 2010 | Philips 60PP9202 60" Rear Projection...
TV power problem
Does anything else work in the same outlet?
Also do you have it plugged into a power strip?
Unplug it wait about 20 - 30 seconds and plug it back in see if it resets its self
Jan 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
More specific
Their is an IC that went out. You can get a replacement chip and repair instructions from www.magnavoxhelp.com
Nov 28, 2006 | Philips 9P5534C 55" Rear Projection...
TV went to black screen
I had the same issue. The screen would shrink and then expand over and over. After thrity minutes it would correct itself.
After a few months of doing this it just broke - no sound and no videe but the power light was still on.
I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
To help others I documented the fix and created a repair kit and step by step quide on how to fix the problem. You can find it here. http://www.magnavoxhelp.com
Aug 02, 2006 | Philips 9P6040C 60" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
478 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
