Question about Remington Electric Chain Saw
I need to remove the orange cover
No I can not find a manual for a remingto 18'electric chain saw model LD4018AW
  • 181 Answers
To me it sounds like the adjuster screw is bent stopping the cover from comming off.bad news is that cover is no longer avalible.the cost on that cover is $5.95 if you can find one.the cover only came as an assembly.you can try this place and see if they have any more.....http://www.masterparts.net/
Posted on Jun 02, 2009
How do i remove the carburator
Here is the illustrated parts manual for your saw. it explains how to strip the saw down and everything you need to know. Please click the 'helpful' tab if you find this useful. Thank you
http://www.mediafire.com/download/n25qmj9j7venncu
May 15, 2016 | Husqvarna 445 18" 45.7cc Gas Powered Chain...
The chain on my 18" ryobi electric chain saw came off. how do I put it back on>
  • Unloosen the bts on the chain cover, remove the cover, loosen the bar for some slack, reposition the chain and reverse the opertaion. Be sure the teeth are going in the correct direction. Tight the chain so a dime will just slip under the chain itself.
Oct 07, 2014 | Ryobi 18-inch Electric Chainsaw Chain Saws
Oil not feeding to the chain guide on the electric ryobi chain saw
Remove the cover on the right hand side of the saw and remove the bar and chain. Clean the oil port holes in the bar and the body of the saw. They get clogged with sawdust and chips. Also clean the groove in the bar and the sprocket at the end of the bar. Always use proper chainsaw bar oil.
Jan 12, 2011 | Ryobi 18-inch Electric Chainsaw Chain Saws
I have a remington 18 inch chainsaw model #EL-9 LD4018AW and need a chain who can I order one from?
Look up Oregon saw on the web for bars and chains to fit nearly every saw made. Good luck!
Dec 22, 2010 | Remington 16" Electric Chain Saw
I think I am missing a part for my Remington lnt-2 12" chainsaw
You do not give us a model number to verify this will work on your saw.
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the "YourModelNumber" - Remington Electric Chain Saw "View Model" link.
  • Click "View Owners Manual" or "View Illustrated Parts Diagram" link.
    • Type "YourPartNumber" into the "Search for your parts by Part #:" window, then click search.
A tension repair kit is available here:
MasterParts.com
http://www.masterparts.net/Merchant2/merchant.mvc?Screen=PROD&Store_Code=MPD&Product_Code=108640-MD
Part number 108640-MD; DESA SPECIALTY PARTS: KIT, ADJUSTMENT SCREW FOR SPROCKET COVER (REM-18); $5.95.
Kit fits the following covers: 108640-01, 116675-01 and 108641-02 (note: for the 108641-02 the screw will adjust from the front with a screw driver, not with a thumb screw at the back) KIT INCLUDES: screw, clip & adjustment block.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 21, 2010 | Remington Electric Chain Saw
Take the chain off a 450 husqvarna
Pages 17 & 18 should help answer your question.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2008/HOUS2008_1151081-96.pdf (This may not be your saw)
Loosen the tension adjuster, remove the clutch cover, (engine to left) pull the bar off the adjustment pin then push it left against the clutch cover bolt. Remove the chain from the chain groove, remove the bar, the chain can now be removed.
You can download the correct Operator's Manual and IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Dec 16, 2009 | Husqvarna 450 e-series 18" Chain Saw
The chain on my Remington electric saw keeps jumping the sprocket. Solution? Thanks.
Depending to what model you have, the Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. Or your cahin is not tensioned properly. According to the manufacturer... "The adjusting block on the adjusting screw isn’t inserted into the adjusting hole on the guide bar. Reinstall and align the sprocket cover by first removing the sprocket cover from the saw. Turn tensioning screw on the sprocket cover counter-clockwise until it stops. Pull guide bar away from saw body to remove slack from chain. Insert sprocket cover tab into saw body tab slot and lower sprocket cover into guide bar bolt. Finger tighten guide bar nut onto guide bar bolt. Slowly push guide bar toward saw body until adjusting block on the adjusting screw drops into round adjusting hole on the guide bar. Securely tighten guide bar nut after properly tensioning saw chain." If these tips do not work, you may need a new chain. You can order an new chain on-line at www.masterparts.net. I hope this helps you!
Jul 01, 2009 | Remington Electric Chain Saw
Remove range cover on remington chainsaw Model LD4018Aw
this web site has partsbreak downs.................http://www.masterparts.net/ hope this hepls,let me know
Jun 01, 2009 | Remington Electric Chain Saw
Remington Electric Chain Saw  Logo
144 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
