Question about Maytag MSD2756G Side by Side Refrigerator
Water is not cooling
The water coming from the dispenser is not coooling.
    Novelist:
  • 103 Answers
Hi: This Wide by side is like all other side by sides as to how it stores the water. Storage will be behind the crisper or meat keeper in the form of a coil of tubing or a bladder to store the water. Pretty simple. The length of tubing running from the storage to the dispenser will not be chilled. Some refrigerators do this better than others. Try setting the ref. or meat keeper a little colder. Watch your vegetables so they don't freeze. Rare, but it's possible... Older homes (before dispensers,) when fridges just had ice makers, would tap into the hot water line for ice to freeze faster and be clearer. I know this sounds crazy but it's true. I lived in an older home and in the winter the hot water would always freeze first. I know this solution sounds lame but there really is nothing much to go wrong with the water chilling. Pull your meat keeper out and look at the reservoir and see how cold it is. Good luck, Jeff
Posted on Jun 01, 2009
How big is the reservoir for the water dispenser? Also, what is the normal temperature of the water being dispensed?
??? You never gave make or model and your mouth is that accurate to tell a 17 degree difference in water temp?
Jul 02, 2015 | Refrigerators
Refrigerator leaking water - can I just shut off water to frig or will that affect its ability to cool?
Shutting off the water to the water dispenser will not affect it's ability to cool. The refridgerator is cooled by a closed freon system not related to the water coming into it for the dispenser.
Mar 18, 2013 | Maytag Refrigerators
Cool water switch seems to be faulty, no water but ice maker seems to be working how do I get access to switch?
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Jan 12, 2011 | Refrigerators
The water does not come out of the cool water dispenser and ice cubes come out when the water dispenser is pushed.
You may have an issue with the "electronic dispenser control board". Also, check your "water reservoir" located in the fresh food area (lower rear area) to ensure that the water is not frozen (if frozen, this will prevent water from dispensing at external dispenser).
Contact an appliance service company.
Feb 16, 2010 | KitchenAid Refrigerators
Water dispenser quit dispensing but the ice maker still makes ice
Chances are that one of the 2 valves in the assembly is bad. It is on the refrig in back, where the water supply line connects. remove the connector to the water dispenser valve (the other is for the icemaker) and connect a jumper power cord to it and then to the wall outlet, momentarily. If water comes out the dispenser, then the valve is good but the switch on the door is bad. If the valve does not hum, the valve is bad.
I have seen the water dispenser lines freeze in the back of the refrigerator, near the water cooling tank or coils, preventing dispensing of water.
Sep 19, 2009 | GE GSH25JFR Side by Side Refrigerator
Warm water is coming out of new refrigator water
Is there a coil of tubing inside the refrigerator? This is how they usually cool the water. If you use a lot of water through the dispenser, the water will become warm.
I hope that this helps.
Tim
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The water in the in-door dispenser is coming out hot
If this freezer is like most, the water going to the dispenser is looped around many times in the refrigerator section near the back. Make sure that this is still true. It must have a lot of water cable in the refrigerator section so that the water has time to cool down before it goes out the dispensor. If for some reason the water tube is touching either the compressor motor or another hot part of the external refrigerator it could cause it to be to hot to cool down in time during its travel through the refrigerator as well as it will start to warm up the refrigerator section as well.
Also, I am sure you have tested, but make sure that you are plugged into the cold water supply and not the hot water supply. Check the water at the connector and see what the temp is at that point before it enters the refrigerator.
My guess is that the coil of water tubing that is usually in the back of the refrigerator section has been either lessend in length or the water entering the refrigerator is too hot to be cooled down in time before it reaches the dispenser.
hth
Feb 03, 2009 | GE GSL25JFPBS Side by Side Refrigerator
MY HAMILTON BEACH WATER DISPENSER MODEL 87307 SERIES A1360CT WILL HEAT BUT NOT COOL THE WATER.
The heating and cooling sections are separate..these are not known to last very long. Sorry. (check the switches though - does the indicater light come on?)
Apr 21, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
Water/ice maker not working and freezer/frig not cooling evenly(top warm/bottom cool)
the relay valve that controls the water is stuck.
likely hard water deposits,
Feb 03, 2008 | Jenn-Air JCD2295HES Side by Side...
Maytag MSD2756G Side by Side Refrigerator Logo
149 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
